Graduate Hydraulic jumps: Why do they occur when/where they do?
Hydraulic jumps occur when fluid transitions from supercritical to subcritical flow, typically at specific points related to critical depth. The location of these jumps depends on various factors, including channel geometry and flow conditions. The discussion highlights a need for deeper understanding of why jumps happen in certain locations rather than allowing continuous supercritical flow. Additionally, a reference to HDS5 - Hydraulic Design of Highway Culverts is suggested for further exploration of hydraulic jumps with less mathematical complexity. Understanding these dynamics is crucial for effective hydraulic design and management.
Brett0
Hi guys,
I've been doing some light reading on hydraulic jumps.
For example:
So I've been through the basics, super critical to sub ciritcal etc:
https://en.wikipedia.org/wiki/Hydraulic_jump
So far I understand that the jump occurs at the two points either side of the critical depth, like we see here:
https://en.wikipedia.org/wiki/Hydra...annels-,Energy loss,the equation for ΔE below.
What I don't get is why does the jump occur in the first place? for example in the video above why doesn't the flow just remain super critical? why does the jump happen at the length-wise location that it does? what does that depend on?
Any thoughts?
Brett
For discussion of hydraulic jumps with less math and more discussion than the Wikipedia hydraulic jump article you referenced above, search a copy (free online) of HDS5 - Hydraulic Design of Highway Culverts.
The text and equations in that document are all believed to be correct, but at least one of the nomograms is wrong by an order of magnitude.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
