Hydraulic Piston on te bottom of a hill
In summary: Or you can use forces: What force is needed to produce that acceleration? But you will need to know the mass of the cart to get the force needed.In summary, a 150 kg cart rolls down a 50 m high hill on a 300 m long track in an amusement park. It experiences a constant resistive force of 70 N from rolling friction and air resistance. The speed of the cart at the bottom of the hill is 26.4 m/s if it starts at rest. To bring the cart to rest at the bottom, a force needs to be applied for a distance of 5.0 m. The method for solving this varies, but it will require knowing the mass of the cart.
jenha14
At a ride in an amusement part a cart, with a mass of 150 kg, rolls down a long curved hill. The height of the hill is 50 m and the length of the track that the cart follows is 300 m. As the cart rolls down the hill, it experiences both a rolling frictional force and air resistance. The net effect of these two resistive forces over the run is equivalent to a constant force of 70 N, which is opposite to the cart's velocity.
(A) If the cart starts out at rest at the top of the hill, what is the speed at the bottom?
(B) There is a large hydraulic piston at the bottom of the hill thate engages the cart and brings it to rest by applying a force for 5.0 m. Neglecting all other resitive forces, what is the magnitude of the force needed to stop the cart?
RELEVENT EQUATIONS
(Uf - Ui) + (Kf - Ki) = -Fd
ATTEMPT AT THE SOLUTION
I found (A) to be 26.4 m/s, but I have no idea on where to start on part (B)
Looks good.
You can solve part (B) in any of several ways. You can use energy methods: How much work is required to bring it to rest? Or you can use kinematics: What acceleration is needed to bring it to rest in the given distance?
Your answer for part (A) is correct. To solve part (B), we can use the relevant equation you provided: (Uf - Ui) + (Kf - Ki) = -Fd.
To start, we need to find the initial kinetic energy (Ki) of the cart at the bottom of the hill. We know that the cart has a mass of 150 kg and a speed of 26.4 m/s. So, Ki = 1/2 * 150 kg * (26.4 m/s)^2 = 110880 J.
Next, we need to find the final potential energy (Uf) of the cart at the bottom of the hill. We know that the height of the hill is 50 m and the mass of the cart is 150 kg. So, Uf = mgh = 150 kg * 9.8 m/s^2 * 50 m = 73500 J.
Now, we can plug in the values into the equation: (Uf - Ui) + (Kf - Ki) = -Fd.
(73500 J - 0 J) + (Kf - 110880 J) = -Fd
Solving for Kf, we get Kf = 184380 J.
This is the final kinetic energy of the cart right before the hydraulic piston engages it. Now, we can use the work-energy theorem to find the force needed to stop the cart.
W = F * d = (Kf - Ki)
Solving for F, we get F = (Kf - Ki)/d.
Plugging in the values, we get F = (184380 J - 110880 J)/5.0 m = 14700 N.
So, the magnitude of the force needed to stop the cart is 14700 N. This is the force that the hydraulic piston needs to apply to bring the cart to a stop in 5.0 m.
FAQ: Hydraulic Piston on te bottom of a hill
What is a hydraulic piston on the bottom of a hill?
A hydraulic piston on the bottom of a hill is a mechanical device that uses liquid under pressure to generate force. It is typically used to control and move heavy objects, such as vehicles or machinery, on an incline.
How does a hydraulic piston on the bottom of a hill work?
The piston is connected to a hydraulic pump, which pressurizes the liquid and forces it into a cylinder. The pressure created by the liquid pushes against the piston, causing it to move. This movement can be used to lift or lower objects on the hill.
What are the benefits of using a hydraulic piston on the bottom of a hill?
One of the main benefits of using a hydraulic piston on the bottom of a hill is that it can provide a strong and consistent force, making it ideal for lifting heavy objects. It is also a relatively simple and reliable system, requiring minimal maintenance.
What are some common applications of a hydraulic piston on the bottom of a hill?
Hydraulic pistons on the bottom of a hill are commonly used in various industries, such as construction, transportation, and manufacturing. They can be found in cranes, forklifts, elevators, and other machinery that need to operate on an incline.
Are there any potential drawbacks to using a hydraulic piston on the bottom of a hill?
One potential drawback of using a hydraulic piston on the bottom of a hill is that it can be expensive to install and maintain. The system also relies on the liquid remaining at a constant temperature and free of any air bubbles, which may require additional equipment or regular maintenance checks.
