Hydraulic Piston Supporting a 500lb weight
To determine the force vector F necessary to support a 500 lb weight using two hydraulic pistons, the equation F1/A1 = F2/A2 was applied, but the initial calculation for F1 was incorrect as it did not account for the lever mechanics involved. The user attempted to incorporate torque by using the formula Torque = rF, but this also yielded an incorrect result. Clarification was provided that the ratio of forces at the pistons and the hand corresponds to the distances from each to the pivot point. This insight helped to refine the approach to solving the problem. The discussion emphasizes the importance of understanding both hydraulic principles and lever mechanics in such calculations.
AsuraSky
Piston 1 in the figure below has a diameter of 0.31 in.; Piston 2 has a diameter of 1.7 in. In the absence of friction, determine the force vector F necessary to support the 500 lb weight.
F1/A1=F2/A2
I used the equation above and found the areas of each piston and solved for F1
F1/.075477=500/2.2698
F1=16.626
That answer was wrong so I thought about it some more and realized that the force I solved for was the force on the piston and not the lever that the question asked for. So I had this crazy idea that since there was sort of a rotational force on the hinge when you push the lever down you can use Torque = rF with torque being the force previously solved for
16.626 = 10(F) (r=10 for the 10 in distance between force F in the diagram and piston 1 in the diagram)
F= 1.6626
This answer was also marked wrong and I have run out of ideas on how to solve this problem. If anyone can point me in the right direction it would be greatly appreciated.
Right method, slight oops.
The ratio of force at the piston and the hand is the ratio of the distances from each of them to the pivot.
Thanks, that cleared things up for me.
  • · Replies 21 ·
