Hydraulic turbine transient performance
So, in summary, when adjusting the guide vanes or wicket gates of a pumped storage unit, there may be a temporary decrease or increase in pressure before the power output adjusts to the desired level. This is due to the need to accelerate or decelerate water flow in the inlet pipes.
kippie
Hi
I am having difficulty explaining to my mechanical engineering supervisors the following:
When a pumped storage unit is in generation mode, synchronised to the grid and in steady state and the guide vanes/wicket gates are opened more to allow more water flow and therefore more power generation, the pressure across the Francis turbine initially decreases before increasing. The pressure is related to the power so therefore there is a power dip first then a increase in power.
Similarly, when the guide vanes are closed to decrease power, the power/pressure first increases before decreasing after a few seconds.
The transfer function of a hydraulic turbine shows this phenomenon with the use of initial value theorem and final value theorem.
Can you help to explain why this happens?
Thanks
:smile:
I'm not an expert on hydraulic turbines, but one possible cause is that to get an increased flow, you have to accelerate the water that is already flowing through the inlet pipes (the penstock). While that is happening, the pressure at the inlet of the turbine will be reduced. The reverse would happen when you reduce the flow.
FAQ: Hydraulic turbine transient performance
1. What is hydraulic turbine transient performance?
Hydraulic turbine transient performance refers to how well a hydraulic turbine responds to sudden changes in flow or load, and how quickly it reaches a steady state after a transient event.
2. What factors affect hydraulic turbine transient performance?
The factors that affect hydraulic turbine transient performance include the type and design of the turbine, the operating conditions, the control system, and the characteristics of the water flow.
3. How is hydraulic turbine transient performance measured?
Hydraulic turbine transient performance is typically measured by analyzing the response of the turbine to a sudden change in flow or load, and evaluating parameters such as speed, torque, and power output.
4. Why is hydraulic turbine transient performance important?
Hydraulic turbine transient performance is important because it affects the stability and efficiency of the turbine during sudden changes in flow or load, and can impact the overall performance and reliability of a hydropower system.
5. How can hydraulic turbine transient performance be improved?
Hydraulic turbine transient performance can be improved through proper design and selection of turbine components, as well as through the use of advanced control systems and strategies. Regular maintenance and monitoring can also help to ensure optimal performance.
17K
