Hydraulics - Problem finding pressure
In summary, the fluid is water, and the static pressure is 1.89MPa at the entrance to the pipe, and 1.47MPa at the exit of the pump. The pressure-losses due to valve, 90 degrees pipe angle change, and entrance to a container are 7, 0.9, and 1, respectively. The fluid flow is 0.22 m3/s. The friction coefficient is 0.02.
Femme_physics
http://img37.imageshack.us/img37/638/pumpyu.jpg
(the pump is between 1 and 2)
D1 = 300mm [diameter of pipe 1]
D2 = 250mm [diameter of pipe 2]
k(pressure lost due to valve) = 7
k(pressure lost due to 90 degrees pipe angle change) = 0.9
K (pressure lost due to entrance to a container) = 1
L1 = 12m [length of pipe 1]
L2 = 60m [length of pipe 2]
Energy conversation efficency of pipe = 75%
Q = 0.22 m^3/s [volumetric flow]
f1 = f2 = 0.02 [friction coeffecient in both pipe]
Fluid is water
Find static pressure at the entrace to the pipe
Find static pressure at the exit of the pump
Answers:
P1/lamda = 1.89m water
P2/lamda = 49.7m water
I can't get p2/lamda as the right result :( http://img810.imageshack.us/img810/1269/scan0007o.jpg
Just a few observations, since I do not understand everything you're doing yet.
I see you have the kinetic pressure correctly now! :)
And I presume the static pressure is ##p \over \lambda##?
You appear to multiply the pressure-losses with the kinetic pressure, but I don't think you should do that.
When you write ##p \over y##, can it be that you mean ##p \over \lambda##?
You multiply the friction coefficient by the length and divide by the squared diameter.
I'm not sure which formula you're using, but I'd expect that you should multiply by the surface area of the pipe, which is the length times pi times the diameter.
Yes! DOn't confuse my y and lamda. It's just how it looks in the book.
That's just what the formula says last I checked.
Again "Yes! DOn't confuse my y and lamda. It's just how it looks in the book.
You multiply the frictioncoefficient by the length and divide by the squared diameter.
OK. I will try this tomorrow morning. thank u.
Isn't your formula the following?
$$H_{S_A} + H_{V_A} + Z_A = H_{S_B} + H_{V_B} + Z_B + \sum Y_{A-B}$$
I don't see that you should multiply ##H_{V_B}## with ##\sum Y_{A-B}##.
Well, they confuse me, but I guess the book must be right. :wink:
Well that's what our teacher said
Well, in your scan you appear to have left out a plus sign in the formula, which I assume is just a typo.
But when you filled in the numbers, you appear to have introduced an extra factor that's not in the formula.EDIT: Wait! I think I'm as yet missing something about the pressure-loss terms that you didn't define yet.
Can you say what the formulas are for the Y terms?
That is, what is the formula due to pressure-loss caused by friction, etcetera?
I just want to apologize for cutting off from this topic and the other hydraulic topic. It appears there is just a big mixture in formulas and definitions in that topic that I just decided to harass my classmates. I decided to leave hydraulics out of physicsforums :)
Related to Hydraulics - Problem finding pressure
1. What is pressure in hydraulics?
Pressure in hydraulics refers to the force applied to a fluid in a confined system, resulting in the fluid exerting a force on the walls of the container or system.
2. How is pressure calculated in hydraulics?
Pressure in hydraulics is calculated by dividing the force applied by the area over which it is distributed. This is known as the Pascal's Law, which states that pressure is equal to force divided by area.
3. What are some common problems with finding pressure in hydraulics?
Some common problems with finding pressure in hydraulics include leaks in the system, incorrect calculations, and issues with the pressure gauge or measuring device.
4. How can I troubleshoot pressure-related issues in hydraulics?
To troubleshoot pressure-related issues in hydraulics, start by checking for any visible leaks in the system. Then, double-check your calculations and ensure that the pressure gauge or measuring device is functioning correctly. If the problem persists, it may be necessary to consult a professional.
5. How does pressure affect the performance of a hydraulic system?
Pressure plays a crucial role in the performance of a hydraulic system. The amount of pressure applied determines the force and speed at which the fluid moves, and ultimately affects the overall efficiency and power of the system.
  • Mechanical Engineering
