Hydro Power is Actually Solar Power
In summary, hydroelectric power is an example of energy produced by gravitational potential. However, from an ultimate perspective, hydro power is actually an example of solar power.
Frank Peters
28
Hydroelectric power, effected usually by damming a river, is ordinary considered an example of energy produced by gravitational potential.
Water must drop to a lower gravitational potential to extract energy, and this drop occurs as a river flows downward. But to keep the dam working indefinitely water must also continuously be elevated, or raised, in potential. This elevation of water occurs via solar heating. The sun vaporizes
water and this water vapor will later condense as rain or snow at higher elevations. Without this continual elevation of large amounts of water to a higher gravitational potential hydroelectric power would not be possible.
This issue may not seem greatly significant but it's always a good idea to try to understand things from different perspectives.
By that definition, all power is either nuclear or solar.
Likes Michael Price, russ_watters and davenn
But we really are not worried about the origins, only the immediate form of energy generation
aka hydro generation
your idea could be used to describe many forms of energy generation ….
wind turbines and tidal to name a couple more.
see if you can come up with any othersDave
Which means it's all nuclear, since that's what powers the sun.
Likes davenn
What about tidal power?
I mentioned that along with wind ... caused by the sun in one form or another
(well some moon as well for the tides)
Likes Michael Price
checkmate 😉
Likes Michael Price
Is that correct?
The nuclear fusion within the sun is caused by gravitational collapse. So it seems that, ultimately, it is gravity that powers everything.
No it isn't.
Likes davenn
Geothermal energy is also not based on Solar. Tidal power is based on the potential energy of Earth Moon ecosystem.
Likes russ_watters
But ultimately by gravity.
russ_watters said:
No it isn't.
It kind of is. Gravitational collapse is the reason the core reached the heat and pressure required for fusion ignition, and is continuing to increase the pressure and temperature in the core (increasing the output of the sun) as the core density increases due to the accumulation of helium. It's not the direct source of the energy coming out of the sun, but it is indirectly responsible.
Likes Anand Sivaram
It can be said to provide activation energy, but that's like saying the blasting cap is the energy source instead of the dynamite. It might be interesting to try and figure out what fraction of the energy that is though...
Likes anorlunda
About one part in a million, from memory. A serious early argument against Darwin was that the Sun was assumed to be radiating its gravitational potential energy and therefore couldn't be much over 10,000 years old. Compare its expected ten billion year lifetime when you factor in fusion.
I may be off by an order of magnitude
Likes cjl, Anand Sivaram, anorlunda and 1 other person
Another nuclear source, right? Isn't the geothermal heat provided by decay of radionuclides in the mantle?
Likes davenn, DaveC426913 and russ_watters
That's what I thought.
Likes davenn
That was one of the big arguments between Lord William Thompson Kelvin and Charles Darwin.
According to Kelvin the source of Solar energy was due to Gravitational contraction. Because of that he kept the age of Sun and Earth to be around 20-100 Million Years. Where as on the first version of "On the origin of species", Darwin said that evolution took more than 300 Million years. Kelvin vehemently opposed it because the Sun was only 20 Million years old. Anyway for the 2nd edition of the book, Darwin avoided the problem by not giving any real number of years. :)
Likes anorlunda
Related to Hydro Power is Actually Solar Power
1. What is hydro power?
Hydro power is a form of renewable energy that uses the force of moving water, such as rivers or streams, to generate electricity. This is typically done through the use of dams or other structures that control the flow of water.
2. How is hydro power related to solar power?
Hydro power is actually a form of solar power because it is ultimately powered by the sun. The sun's energy heats up the Earth's surface, causing water to evaporate and form clouds. When these clouds release rain, it flows into rivers and streams, which can then be harnessed for hydro power.
3. What are the benefits of using hydro power?
Hydro power is a clean and renewable source of energy, meaning it does not produce harmful emissions or contribute to climate change. It is also reliable and can provide a constant source of electricity, unlike other forms of renewable energy such as wind or solar power.
4. Are there any drawbacks to using hydro power?
One potential drawback of hydro power is its impact on the environment. Building dams and other structures can disrupt natural habitats and alter the flow of rivers, potentially harming wildlife. Additionally, hydro power can be costly to build and maintain.
5. How much of the world's energy comes from hydro power?
Currently, about 16% of the world's electricity is generated by hydro power. However, this varies greatly by country and region. For example, some countries, such as Norway and Brazil, rely heavily on hydro power for their energy needs, while others may have little to no hydro power production.
  • Thermodynamics
  • Mechanical Engineering
