Hydrocarbon empirical formula question
In summary, the problem involves a hydrocarbon being burned in oxygen to produce a mixture of CO2 and H2O. The total pressure of the mixture is given as 1.200 atm and the partial pressure of H2O is 0.686 atm. Using the equation pV=nRT and the relationship between partial pressures and number of molecules, the empirical formula of the hydrocarbon is found to be C3H8, also known as propane. The process involves finding the ratio of H2O molecules to CO2 molecules and then using this ratio to determine the ratio of m to n in the empirical formula.
lastlanding
Q. A Hydrocarbon (CnHm) is burned completely in oxygen to produce a mixture of CO2 and H2O. The total pressure of mixture is 1.200 atm and partial pressure of H2O is 0.686 atm. What is empirical formula of Hydrocarbon
pV=nRT
pa/ptotal = na/ntotal
The answer is C3H8 aka Propane
Im so confused! I don't even know where to start with this!
Find the partial pressure for the CO2. The partial pressures of the gases are proportional to the number of molecules, so you've immediately got the ratio of the number of H2O molecules to the number of CO2 molecules. This is almost m/n, but note that because of the H2 there are twice as many H's as H2O's, so you've really got the ratio of m/2 to n. It should then be easy to get the ratio m to n. Then you start guessing - if n=1 does m work out to an even number? If not, try n = 2 and so on.
I understand that this question involves the use of the ideal gas law and partial pressures to determine the empirical formula of the hydrocarbon. To start, we can use the ideal gas law equation, pV=nRT, to calculate the number of moles of the total mixture. From the given information, we know that the total pressure is 1.200 atm and the total volume is not specified, so we can assume a convenient value such as 1 L. The temperature and gas constant are also given constants, so we can rearrange the equation to solve for n, the number of moles.
n = (pV)/(RT) = (1.200 atm * 1 L)/(0.08206 L*atm/mol*K * 298 K) = 0.048 mol
Next, we can use the partial pressure equation, pa/ptotal = na/ntotal, to determine the number of moles of H2O in the mixture. We know that the partial pressure of H2O is 0.686 atm, and we can calculate the total number of moles from the previous step.
na = (pa/ptotal) * ntotal = (0.686 atm * 0.048 mol)/(1.200 atm) = 0.0274 mol
Now, we can use the molar ratio between H2O and the hydrocarbon to determine the number of moles of carbon and hydrogen in the hydrocarbon. From the empirical formula, we know that there are 3 carbon atoms and 8 hydrogen atoms in the molecule. Therefore, for every 3 moles of H2O, there must be 1 mole of CnHm.
nC = (1 mol CnHm)/(3 mol H2O) * 0.0274 mol H2O = 0.00913 mol C
nH = (8 mol CnHm)/(3 mol H2O) * 0.0274 mol H2O = 0.0731 mol H
Finally, we can use these values to determine the empirical formula of the hydrocarbon by dividing the moles of each element by the lowest number of moles, which in this case is 0.00913 mol.
C: 0.00913 mol / 0.00913 mol = 1
H: 0.0731 mol / 0
Related to Hydrocarbon empirical formula question
1. What is a hydrocarbon empirical formula?
A hydrocarbon empirical formula is a simplified representation of the ratio of elements in a hydrocarbon compound. It is the simplest whole number ratio of carbon and hydrogen atoms in a molecule.
2. How do you calculate the empirical formula of a hydrocarbon?
To calculate the empirical formula of a hydrocarbon, you need to know the mass of each element in the compound. Then, you divide the mass of each element by its atomic mass and convert the resulting values to whole numbers. These whole numbers represent the subscripts in the empirical formula.
3. What is the importance of the empirical formula in chemistry?
The empirical formula is important in chemistry because it provides important information about the composition of a compound. It can be used to determine the molecular formula, which gives the exact number of atoms of each element in a molecule.
4. Can a hydrocarbon have more than one empirical formula?
Yes, a hydrocarbon can have more than one empirical formula. This is because different molecules can have the same ratio of elements and therefore the same empirical formula. However, they may have different molecular formulas.
5. What is the difference between empirical and molecular formula?
The empirical formula represents the simplest ratio of atoms in a compound, while the molecular formula gives the actual number of atoms of each element in a molecule. The molecular formula is either equal to or a multiple of the empirical formula.
