funcosed
- 37
The flow of a single sphere translating at speed U in a fluid at rest far away from the sphere is given by the streamfunction,
ψ(r,Θ) = (1/4)Ua2(3r/a - a/r)sin2Θ a=radius of sphere
the origin is at the centre of the sphere and the axis Θ = 0 is parallel to U.
It has already been established that the streamfunction consists of a stokeslet and a dipole and at a distance D the dipoles influence is negligible.
Now consisder sedimentation of two spheres A and B separated by a distance d (d >> a and d > D). Both spheres move under the influence of gravity (g = gez)at the same speed.
The angle between a line joining the centre of the spheres and the vertical is α (alpha).
The velocity is U = U0+(a/d)U1+...
The neglected terms are of order O((a/d)2). What is value of U0 and show that the next order each sphere induces a velocity (a/d)U1 on the other one. Provide an expression for U1 and a rough plot for each sphere.
Velocity components given by Stokes stream function:
Ur = (1/r2sinΘ)∂ψ/∂Θ
UΘ = (-1/rsinΘ)∂ψ/∂r
Taking the origin to be at the centre of sphere A its stream function is the expression given above. The stream function for B is the same but with r translated by d, i.e. r = r+d. Is this correct?
Then I think the superposition of the two can then be used to calculate the velocity via stokes stream function given above. Is this the right approach?
The I take it U0 will be the part of the expression that has no a/d term and U1 will be the part with an a/d term ??
