Hydrogen Atom: Wavefunction collapse after measurement of Lz
In summary: the wave function may still be a superposition of states with angular momentum values of ##l=2, 3, 4##.
Joker93
504
37
Suppose we have a wavefunction with n=4. If we measure the orbital angular momentum along the z-direction(no spin in this problem) and get 2*hbar then what are the possible values of the total angular momentum and what is the most general wavefunction after the measurement?
l=0,1,2,..,n-1
m=-l, -l+1,..., l-1, l
Lz=m*hbar
Since n=4--> l=1, 2, 3. Since we measured Lz and found it to be 2*hbar, then m=2 which could only correspond to l=2 or l=3.
Now, since m=2 but we don't know l, the most general wavefunction after the measurement could only be C*R4l*Y[l=l m=2] where C is just a normalization constant.
But, my professor said this is wrong and the most general wavefunction is:
C1*R42*Y[l=2 m=2]+C2*R43*Y[l=3 m=2].
But, I can't understand why. When we measure Lz, then doesn't the wavefunction collapse to a state of particular l(here 2 or 3 depending on the total angular momentum that the wavefunction had before measurement) and m(here 2)?
Thanks in advance
How can you rule out the ##l = 3## case?
Or, look at it this way: Your professor's wave function would give measurements of ##n=4## and ##l=2## and it's more general than your wave function.
So, if we measure the z component of the angular momentum the wavefunction collapses to a superposition of all the spherical harmonics(with their corresponding radial part) with m that corresponds the the measured value of Lz? I thought it would collapse a a particular(not superposed) wavefunction with spherical harmonic part with l being the l of the total angular momentum. Why isn't this true though? I might have a gap in my knowledge of the subject.
Joker93 said:
But I can't understand why. When we measure Lz, then doesn't the wave function collapse to a state of particular l (here 2 or 3 depending on the total angular momentum that the wavefunction had before measurement) and m(here 2)?
Suppose the answer to your question is yes. If the atom was in the state your professor said, a measurement of Lz would always corresponds to m=2. How do you propose to choose whether to keep the l=2 or l=3 piece of the wave function?
Well, my answer was based on that I can't know! That's why i wrote the solution as Y[l=l, m=2]. I thought that the wavefunction would collapse to a single eigenstate of l. But, I can't understand why his answer is right and mine is wrong.
I didn't rule out l=3. My answer kept l=l.
So why'd you choose l=2 instead of l=3?
Joker93 said:
My answer kept l=l.
You're assuming there's a definite ##l## initially. Is that justified?
Loosely speaking the wavefuction only collapses as much as it needs to! You mention spin: Unless you measure spin the spin component of the overall wave function will not collapse at all.
Ι did not choose l=2 or l=3. I just say that we can't know.
Isn't l the l of the total angular momentum?
Sorry, I didn't see that. What does ##l=l## mean?
I did not understand where does spin come into play.
I meant that I just wrote Y[l, 2]. I kept l general. Unknown.
You mean that the initial wavefunction could be in a superposition of eigenstates of different l's and m's and upon measurement it collapsed to a superposition of those eigenstates with the measured m? That is, you are implying that my solution took as granted that the initial wavefunction was in a superposition of states but only one of those had m=0, right?
In this case, you would have a definite value for ##l## you just don't know what it is. That is fundamentally different from it could be either. Until you measure ##l## you can't say it has a definite value. It could still be 2 or 3, hence by definition it is a superposition of those states.
The wave function collapse doesn't result in a definite value of all compatible observables. For example, after you measure ##n=4## you don't have a definite value of anything other than ##n##. Everything else is not unknown - in terms of definite values that you just don't know yet. They do not have a definite value into they are measured.
Does that make sense?
This is quite fundamental to QM.
Yes, I understand what you mean. So, is my previous comment correct then(my response to vela)?
Possibly but I didn't understand the bit about m = 0.
Your misunderstanding was quite subtle so it's hard to explain.
I'm offline for a bit now.
Sorry, I meant m=2.
To rephrase, I meant that in my solution(where the wavefunction collapses to a single eigenstate of l) took as granted that the initial wavefunction(the one before the measurement) had only one eigenstate of m=0 along the superposed eigenstates. And this is wrong because the superposition(the initial wavefunction) could contain any eigenstate with m=2(in this case it could contain an eigenstate with Y[2 2] and an eigenstate with Y[3 2]) and not just one like my solution implied(because I only wrote Y[l 2] and took for granted that we also knew l).
Did I get it right?
Joker93 said:
Sorry, I meant m=2.
Did I get it right?
I think that's right. If you measure all three quantum numbers, then (after those measurements) you have a wavefunction of the form: ##\psi_{nlm}##, where ##n, l, m## are the results of your measurements. But, the most general state of the hydrogen atom is not ##\psi_{nlm}##, where ##n, l, m## are unknowns (*).
(*) This would suggest that the hydrogen atom, before measurement, has definite values for the quantum numbers, which you find out by measuring them. This is not the case.
Instead, the most general state is:
$$\sum_{n, l, m} C_{nlm} \psi_{nlm}$$
This implies that the quantum numbers do not have definite values until you measure them. And, if you measure only one, the others do not assume definite values until they too are measured. After a measurement of ##n=4##, the most general state is:
$$\sum_{l, m} C_{lm} \psi_{4lm}$$
Where ##l,m## take all the allowed values compatible with ##n = 4##.
And, after a further measurement of ##m=2## the most general state is:
$$\sum_{l} C_{l} \psi_{4l2}$$
Where ##l = 2, 3##.
That's the process by which you should have reached the answer. Hope that helps.
Likes Joker93
Where ##l = 2, 3##.
Yes, that's how I understood this. Thanks a lot!
FAQ: Hydrogen Atom: Wavefunction collapse after measurement of Lz
What is a hydrogen atom?
A hydrogen atom is the simplest type of atom, consisting of one proton in the nucleus and one electron orbiting around it. It is the most abundant element in the universe and plays a crucial role in many chemical reactions.
What is wavefunction collapse?
Wavefunction collapse is a concept in quantum mechanics that describes the change in the probability distribution of a particle's location or state after it has been measured. It is the sudden reduction of the particle's many possible states into one definite state.
What is Lz in relation to a hydrogen atom?
Lz, also known as the z-component of angular momentum, is a quantum number that describes the orientation of an electron's orbital angular momentum in relation to the nucleus. In a hydrogen atom, it represents the electron's orbital motion along the axis of the atom's nucleus.
How does Lz affect the wavefunction collapse of a hydrogen atom?
After the measurement of Lz, the wavefunction of a hydrogen atom will collapse into one of its possible eigenstates, corresponding to a specific value of Lz. This is because Lz is a quantum observable, meaning it can be measured and will have a definite value upon observation, causing the collapse of the wavefunction.
Can the wavefunction collapse of a hydrogen atom be predicted?
The wavefunction collapse of a hydrogen atom cannot be predicted with certainty, as it is a random process. The probability of the wavefunction collapsing into a specific state can be calculated using mathematical equations and principles of quantum mechanics, but the exact outcome cannot be determined beforehand.
