Hydrogen bonding between water and other molecules.
In summary, when drawing hydrogen bonds between a water molecule and H3PO4 or acetic acid, the hydrogen bond is formed between the polarized hydrogen atom and either the oxygen or hydrogen atom of the compound. In the case of acetic acid, it is more favorable for the hydrogen bond to be formed with the doubly bonded oxygen atom due to its higher electronegativity. However, both options are possible if there are polarized hydrogen and oxygen/hydrogen atoms present.
Puchinita5
183
I have attached a solution to one of my homework questions that states "Draw hydrogen bonds that might be formed between a water molecule and the following compounds: a) H3PO4; b) PO43-; c) aniline; d) pyridine; e) ethylamine; f) ethyl ammonium ion; g) acetic acid."
My question is specifically for H3P04 and Acetic acid. Why is it that in H3PO4, the H on the OH makes the hydrogen bond with the O of a water molecule, but in acetic acid, the lone electron pair on the OH makes the hydrogen bond with the H of a water molecule.
Does it make a difference if I instead drew a hydrogen bond from the lone electron pair of the OH on H3PO4 and connected this to the H of water? Is it the same thing or is there a reason these are like this?
A Polarized Hydrogen atom makes Hydrogen bond with Polarized F, O, N and to some extent, Cl.
Water molecule will form Hydrogen Bonds from both Oxygen and Hydrogen atoms as the species you mentioned, Phosphoric Acid and Acetic Acid, have both polarized O and H atom.
But I feel that, in Acetic Acid, Water must form H-Bond from Doubly Bonded Oxygen atom and Acidic Hydrogen, as the O atom in C=O is more electronegative than O atom in C-O-H, hence having more electron density and tendency to attract partially positive H atom of water molecule.
If there are polarized H and F/O/N atom, you can draw H-Bond with both of them, which you should.
Related to Hydrogen bonding between water and other molecules.
1. What is hydrogen bonding?
Hydrogen bonding is a type of intermolecular force that occurs between a hydrogen atom bonded to an electronegative atom (such as oxygen or nitrogen) and another electronegative atom in a different molecule. This results in a relatively strong attraction between the two molecules.
2. How does hydrogen bonding occur between water and other molecules?
In water, the positively charged hydrogen atoms (due to their unequal sharing of electrons with oxygen) are attracted to the negatively charged oxygen atoms of nearby water molecules, forming hydrogen bonds. These bonds are responsible for the unique properties of water, such as its high surface tension and its ability to dissolve many substances.
3. What types of molecules can form hydrogen bonds with water?
Molecules that contain highly electronegative atoms, such as oxygen, nitrogen, or fluorine, can form hydrogen bonds with water. This includes many compounds found in nature, such as sugars, alcohols, and acids.
4. How does hydrogen bonding affect the physical properties of water?
The presence of hydrogen bonding in water results in several unique physical properties, such as a high boiling point, high surface tension, and the ability to dissolve polar and ionic substances. These properties are essential for life on Earth and make water a versatile solvent in many natural and industrial processes.
5. Can hydrogen bonding occur between molecules of different substances?
Yes, hydrogen bonding can occur between molecules of different substances. For example, water can form hydrogen bonds with other compounds, such as ethanol or ammonia, resulting in mixtures with unique physical properties. Additionally, hydrogen bonding can occur between molecules within the same substance, such as between different water molecules, contributing to the cohesive nature of water.
