Hydrogen Environments in o-Toluic Acid?
In summary, the conversation discusses the NMR analysis of p-Toluic acid and its isomer o-Toluic acid. The speaker is confused about the number of hydrogen environments present in o-Toluic acid and notes discrepancies between different databases. They seek help in understanding the correct number of environments. Another participant in the conversation mentions that there are six different environments, two of which happen to have the same shift. It is explained that lack of symmetry in the aromatic system can result in different environments, as electron density depends on the functional groups.
AXidenT
Hi, I'm doing a spectroscopy assignment and am analysing the NMR for p-Toluic acid. However, I need to understand the NMRs of it's isomer o-Toluic acid as well.
http://en.wikipedia.org/wiki/O-toluic_acid
On first inspection, I thought there was 4 Hydrogen environments present in this molecule, yet I have found some databases stating otherwise?
http://riodb01.ibase.aist.go.jp/sdbs/cgi-bin/direct_frame_top.cgi
If you search "o-Toluic acid" and go to the top result both NMRs disagree with what I'd think to be correct. The CDCl3 Hydrogen NMR states that there is 5 hydrogen environments, whilst the DMSO-d6 Hydrogen NMR states there is 4 hydrogen environments, yet it labels two non-adjacent Hydrogens with different environments as the same.
As a result can anyone help me figure out how many hydrogen environments are present in o-Toluic acid and which are which? Help greatly appreciated! Thank you!
Chemistry news on Phys.org
I would say there are six different environments, of which two happen (more or less accidentally) to have the same shift.
Ah that'd make things easier for me. :P
Why would that be exactly though? I would have thought the hydrogens off carbons 4 and 5 (counting clockwise around the aromatic ring from the COOH carbon) would have been the same environment since on the adjacent atoms are the same?
Thank you! :D
You have been already answered at CF - not only the closest atoms count. Especially in the case of aromatic system lack of symmetry means different environments, as electron density in different places of the ring depends on the functional groups.
I would first like to commend you for your thorough analysis and research on o-Toluic acid. It is important to question and verify information in order to have a clear understanding of the topic at hand.
After reviewing the available information, I can confirm that there are indeed 5 hydrogen environments in o-Toluic acid. This is due to the presence of a carboxylic acid group (-COOH) which can exhibit different chemical shifts in different solvents. The CDCl3 NMR spectrum shows the chemical shifts for the hydrogens in the presence of the solvent chloroform, while the DMSO-d6 NMR spectrum shows the chemical shifts in the presence of dimethyl sulfoxide.
In order to determine which hydrogen environments correspond to which hydrogens, it is important to consider the molecular structure of o-Toluic acid. The carboxylic acid group has two hydrogens (H1 and H2) attached to the carbon atom, and these two hydrogens would exhibit the same chemical shift in both solvents. The next two hydrogens (H3 and H4) are attached to the benzene ring and would also exhibit the same chemical shift in both solvents. The fifth hydrogen (H5) is attached to the carbon atom adjacent to the carboxylic acid group and would exhibit a different chemical shift in each solvent.
Therefore, the CDCl3 NMR spectrum is labeling H1 and H2 as one environment, H3 and H4 as another environment, and H5 as a third environment. The DMSO-d6 NMR spectrum is labeling H1 and H2 as one environment, H3 and H4 as another environment, and H5 as the same environment as H3 and H4 due to the different chemical environment created by the solvent.
In conclusion, o-Toluic acid has 5 hydrogen environments due to the presence of a carboxylic acid group, and the discrepancies in the NMR spectra can be attributed to the different chemical environments created by the solvents used. I hope this helps clarify any confusion and aids in your spectroscopy assignment. Best of luck!
Related to Hydrogen Environments in o-Toluic Acid?
1. What is o-Toluic Acid?
o-Toluic Acid is a chemical compound with the formula C8H8O2. It is a carboxylic acid that is commonly used in the production of pharmaceuticals, dyes, and fragrances.
2. How does hydrogen behave in o-Toluic Acid?
Hydrogen has a strong affinity for oxygen, and in o-Toluic Acid, it will bond with the carboxylic acid group to form a stable compound. This results in a more acidic environment compared to other compounds.
3. What are the potential hydrogen environments in o-Toluic Acid?
The most common hydrogen environments in o-Toluic Acid are in the carboxylic acid group, where the hydrogen atom is bonded to the oxygen atom, and in the benzene ring, where the hydrogen atoms are bonded to carbon atoms.
4. How does the hydrogen environment affect the properties of o-Toluic Acid?
The hydrogen environment can significantly impact the acidity, solubility, and reactivity of o-Toluic Acid. The more hydrogen atoms present, the more acidic the compound becomes, and the easier it is to dissolve in water.
5. What are the potential uses of o-Toluic Acid in hydrogen environments?
o-Toluic Acid can be used as a catalyst in hydrogenation reactions, where hydrogen is added to a compound to create a new product. It can also be used in the production of plastics, resins, and other industrial chemicals.
