Hydrogen peroxide as an oxidising agent
In summary, the conversation discussed the use of hydrogen peroxide as an oxidizing agent under basic conditions to oxidize Mn2+ ions to MnO2. It was noted that hydrogen peroxide can decompose in base, leading to the release of oxygen gas. The presence of MnO2 as a catalyst in the reaction was also mentioned, which may explain why some individuals observed gas being liberated while others did not. The conversation ended with gratitude for the information exchanged.
Moogie
168
Hi
I recently did a reaction (see my last post for specifics) where hydrogen peroxide acted as an oxidising agent under basic conditions to oxidise Mn2+ ions in solution to MnO2
It did look as if some gas was liberated but hydogen peroxide only liberates oxygen when it is reduced.
Hydrogen peroxide can decompose in base so I'm thinking maybe the gas was oxygen released this reaction occurring simultaneously.
The only species available to react were chloride ions, hydroxide ions and water.
Thanks
MnO2 is a catalyst that nicely decomposes hydrogen peroxide. Many metal oxides do the same.
Ah right, so the hydrogen peroxide is oxidising the Mn2+ to MnO2 and then the Mn02 produced is actually catalysing the breakdown of any excess hydrogen peroxide.
That would explain why some people had gas liberated and others didn't - the ones with gas chucked in loads of peroxide!
Thanks very much
for sharing your experiment with us. Hydrogen peroxide is indeed a common oxidizing agent that is often used in chemical reactions. When hydrogen peroxide is added to a basic solution, it can act as an oxidizing agent by accepting electrons from other compounds, causing them to be oxidized. In your experiment, the Mn2+ ions were oxidized to MnO2 by hydrogen peroxide, which itself was reduced to water.
It is possible that the gas observed in your reaction was oxygen, as hydrogen peroxide can decompose into oxygen and water under certain conditions. However, it is also possible that the gas was a byproduct of another reaction occurring simultaneously, as you mentioned.
In addition to chloride ions, hydroxide ions, and water, there may have been other species present in the solution that could have reacted with the hydrogen peroxide. Further investigation and analysis of the reaction products could help identify the exact nature of the gas liberated.
Overall, your experiment demonstrates the versatility of hydrogen peroxide as an oxidizing agent in basic conditions. Its ability to accept electrons and cause oxidation reactions makes it a useful tool in many scientific and industrial processes. Thank you for sharing your findings with us.
Related to Hydrogen peroxide as an oxidising agent
What is hydrogen peroxide?
Hydrogen peroxide is a chemical compound with the formula H2O2. It is a clear, colorless, and slightly viscous liquid that is commonly used as an oxidizing agent in various industries.
What is the role of hydrogen peroxide as an oxidizing agent?
Hydrogen peroxide is a powerful oxidizing agent that is capable of breaking down into reactive oxygen species. It is commonly used in industries such as paper and textile production, water treatment, and in the production of certain chemicals.
How does hydrogen peroxide act as an oxidizing agent?
Hydrogen peroxide acts as an oxidizing agent by donating oxygen atoms to other substances. This causes a chemical reaction known as oxidation, which results in the breaking of chemical bonds and the production of new substances.
Is hydrogen peroxide safe to use as an oxidizing agent?
In low concentrations, hydrogen peroxide is generally safe to use as an oxidizing agent. However, it can be corrosive and cause irritation or burns if it comes into contact with skin or eyes. It is important to handle it with caution and follow safety guidelines when using it.
What are the advantages of using hydrogen peroxide as an oxidizing agent?
One of the main advantages of using hydrogen peroxide as an oxidizing agent is that it is a cleaner and more environmentally friendly alternative to other oxidizing agents. It also has a wide range of applications and is relatively inexpensive compared to other oxidizing agents.
10K
9K
10K
