Hydrostatic forces on a gate with no width?
In summary, the problem involves a gate placed at the bottom of a dam wall, hinged so that there is 1.2m above the pivot point and 0.8m below. As the height of the water increases, the force on the upper section of the gate will increase and eventually open the gate. The task is to calculate the size of "H" in order for the gate to open, using the equations for resultant force and position, and taking into account the width and pressure of the water. By considering the gate as one entire area and ensuring that the resultant force is above the pivot point, the solution can be found. However, integrations can also be used to calculate the moments on the parts of the gate above
veryc0nfused
Hydrostatic forces on a gate with no width??
A gate is placed at the bottom of a dam wall at a distance of "H" below the surface (measured from the top of the gate). The gate is hinged so that there is 1.2m above the pivot point and 0.8m below the pivot. A stop is placed at the bottom of the gate to stop it from rotating. As the height of the water increases the force on the upper section of the gate will increase and eventually open the gate. Calculate the size of "H" in order for the gate to open.
*no gate width was given
*fluid in question is water
F(resultant)=γ.yc.A
F(position)=I/(yc.A)+yc
I know the solution for this question is 0.666m from the answers. So far I have used the resultant force equation to calculate the force for both the top and bottom section of the gate and then attempted to find the force position using the second equation before finally putting this information into a moment equation about the pivot point. My only problem is that the only examples i can find use a gate width and so far using this method I haven't been able to come to answer that matches. In both of the equations I have listed I have attempted to substitute length of the gate for area, however, obviously this doesn't work. Any help would be great, thanks!
hi veryc0nfused! :smile:
veryc0nfused said:
… My only problem is that the only examples i can find use a gate width and so far using this method I haven't been able to come to answer that matches. In both of the equations I have listed I have attempted to substitute length of the gate for area, however, obviously this doesn't work.
just call the width "w", and write out all the equations …
you'll find the w will cancel out at the end! :wink:
show us what you get :smile:
Okay, still not managing to get the correct answer no matter what I do, hoping someone can give me a hand?
My current method involves breaking the top and bottom section of the gate into two areas and considering them separately. Therefore;
Force (top) = 9810(H+0.6)(1.2w)
Force (bot) = 9810(H+1.2)(0.8w)
Meaning the position of these forces are;
Position (top) = [0.144/(1.2H+0.72)]+(H+0.6)
Position (bot) = [0.043/(0.8H+1.28)]+(H+1.6)
I then attempted to substitute these equations into the moment about the pivot using the distance for each force as:
Distance (top) = (H+1.2)-position
Distance (bot) = (H+2)-position
However, doing this created a huge equation and the final result did not match in the end. I'm assuming there must be an easier way of going about this but just can't seem to find it?
before we go any further …
i don't understand how this gate works :confused:
Don't forget the units. How did you get 0.6 (which is right)?
The 1.2 here is wrong.
Where do all those numbers come from? Why do you multiply H with something?
It would be useful if you start with formulas, and then plug in numbers. This makes it easier to understand what you calculate.
Hmm, force depends on height... do you know integrals?@tiny-tim: The upper part can go outwards, pushing the lower part inwards - if the torque on the upper part exceeds the torque on the lower part (in magnitude).
Okay, realized I was going about it all wrong. I ended up solving the question (I think but very open to criticism) by considering the gate as one entire area. By doing this all i had to do was consider the position of the resultant force and make sure that it would be above the pivot point. Thoughts?
sorry, still don't understand :confused:
since the gate is totally submerged, what difference does it make?
veryc0nfused said:
I ended up solving the question … by considering the gate as one entire area.
yes, you can certainly do that :smile:
That is a good approach.
The gate is "in" the dam - one side is not in the water. The height-dependent pressure depends on the height above the water - as the areas are not equal, the total torque depends on the height of the water level.
You need to do integrations to get the moments on the parts of the gate above and below the pivot. Let x be the distance measured above the pivot, and y be the distance measured down from the pivot. The pressure in the region above the pivot is:
[tex]p=ρg(H+1.2-x)[/tex]
The pressure in the region below the pivot is:
[tex]p=ρg(H+1.2+y)[/tex]
The differential force on the region of the gate above the pivot between x and x + dx is:
[tex]dF=wρg(H+1.2-x)dx[/tex]
where w is the width of the gate.
The differential moment about the pivot in this same region is:
[tex]dM=wρg(H+1.2-x)xdx[/tex]
Similarly, for the region below the pivot,
[tex]dM=wρg(H+1.2+y)ydy[/tex]
The moment equation above the pivot has to be integrated between x = 0 and x = 1.2. The moment equation below the pivot has to be integrated between y = 0 and y = 0.8.
You then set the moments for the two regions equal to one another.
chet
Related to Hydrostatic forces on a gate with no width?
1. How are hydrostatic forces calculated on a gate with no width?
Hydrostatic forces on a gate with no width can be calculated using the formula F = ρghA, where F is the force, ρ is the density of the fluid, g is the acceleration due to gravity, h is the depth of the fluid, and A is the surface area of the gate.
2. What is the significance of a gate having no width in relation to hydrostatic forces?
A gate with no width means that it has an infinitely small surface area, which greatly affects the calculation of hydrostatic forces. This is because the force is directly proportional to the surface area, so a smaller surface area results in a smaller force.
3. How do hydrostatic forces on a gate with no width affect the design of a dam or canal?
Hydrostatic forces on a gate with no width play a crucial role in the design of dams and canals, especially in determining the strength and stability of the structures. Engineers must carefully consider these forces when designing the gates to ensure their ability to withstand the pressure of the water.
4. Can hydrostatic forces on a gate with no width be affected by the type of fluid?
Yes, hydrostatic forces on a gate with no width can be affected by the type of fluid. The density of the fluid, which is used in the calculation of the force, varies depending on the type of fluid. For example, seawater has a higher density than freshwater, resulting in a greater force exerted on the gate.
5. What are some potential consequences of not accounting for hydrostatic forces on a gate with no width?
If hydrostatic forces on a gate with no width are not properly accounted for, it can lead to structural failures, such as the gate buckling or breaking under the pressure of the water. This can result in flooding, damage to surrounding structures, and even loss of life. Therefore, it is crucial to accurately calculate and consider these forces in the design and maintenance of gates.
