Hydrostatics with density and area
In summary, the conversation discusses the calculation of the total force exerted by fresh water on a rectangular dam with a depth of 25m and width of 100m. The correct method is to integrate the pressure as a function of depth, which is given by p(z) = ρgz, over the total area of the dam. This results in a second order function of depth, and the calculated force should match the actual answer of 3.1*108 N. The conversation also touches on the importance of using the correct symbols and equations in calculations.
Patricia Reid
A dam is made which is rectangular and flat in profile. It is a depth of 25m and a width of 100m and holds back fresh water which has a density of 1000 kg m3 .
What is the total force that the water exerts on the dam?
F=ρA
|dF|=pdA
d/dz p=-ρg
The hint given was: You will need to express the force as a function of vertical position, and then integrate over the possible values of vertical position.
So the area would be 25(100)=2500 m2.
You could also do some algebra and eventually get d/dz F=-ρgA and then you could integrate this...but it doesn't get you the correct answer.
Any help would be much appreciated!
What is the pressure at depth z, if z is measured downward from the surface?
Chet
It is difficult for us to tell you where you are going wrong if you don't show us what you have done.
The pressure is a linear function of z, let's call it p(z).(Your expression does not appear to contain the z term).
So the force on the dam over a horizontal strip dz in width at depth z is p(z)A = p(z)wh = p(z)wdz where w is the width of the dam (100 m). Just integrate that over the whole depth (25 m). It should be a second order function of z.
AM
Chet
Ok thanks! So pressure would be ρgh=(1000)(9.8)(25)= 2.45*105 Pa
then you could use the equation p=F/A to find F but this would give you 6.125*108 N which is double than the actual answer of 3.1*108 N
I asked for the pressure as a function of z (algebraically). I repeat my question.
Chet
Chet
p=ρgz
AM
Ok thanks!
I'm still a little confused though...So p(z)A is the force right? And if you were to integrate this: p(z)wh = p(z)wdz you would get p(z)wz from 25 to 0?
Patricia Reid said:
p=ρgz
Good. So you can see that the pressure is varying with depth. So you can't just multiply the pressure at the bottom by the total area to get the force. When you did that, you got twice the correct answer. You need to integrate the pressure over the area. The differential area that the pressure at depth z is acting upon wdz. Now use that to integrate the pressure over the area.
Chet
Chet
So F=ρA
=ρgw∫dx
integrate
=ρgwx from 25 to zero
I'm still doing something wrong though...
Patricia Reid said:
So F=ρA
=ρgw∫dx
integrate
No. ##F =\int pwdz=\int(ρgz)wdz## from 0 to 25. (Do you see why?)
Chet
Chet
Yes I think so because F=P*A which you need to change P into density which gives ρgz. Also the pressure is always changing with the depth you cannot use the fixed area so you need the change in height times the length.
Thanks for all your help!
Patricia Reid said:
Ok thanks!
It is not exactly a matter of changing p into density. You are trying to determine force on a slice of the dam at a depth of z.
F = pA where p is the pressure at a depth of z and A is the area of a strip of the dam that is w by dz. Pressure depends only on the depth. ##p(z) = mg/A = \rho Vg/A = \rho Azg/A = \rho zg##
So ##F = \int_0^h p(z)dA = \int_0^h g\rho zdA = \int_0^h g\rho zwdz = wg\rho\int_0^h zdz##
Hi Andrew.
Are you sure you want to follow this particular line of reasoning? We have already gotten Patricia to accept the relation that ##p(z) = \rho zg##. Going back to the version p = W/A (where A is the horizontal area and W is the weight of the overlying fluid) is, IMHO, counterproductive, because it only works if the walls of the container are vertical. Also, you are using the symbol A for two different area entities, thus possibly adding to the confusion. Please consider removing or editing this portion of the text.
Chet
Chestermiller said:
Hi Andrew.
Hi Chet.
The pressure at depth z is determined by the weight of the water above z per unit area. How else does one determine the pressure at depth z? Because it is a fluid, the pressure is omnidirectional - so we can determine the horizontal force per unit area acting on the dam. What container are you referring to?
AM
Andrew Mason said:
Hi Chet.
AM
If the vessel were a truncated cone with the smaller cross section on the bottom, the pressure on the bottom area would not be equal to the weight of the overlying liquid divided by the bottom area. The slanted side walls would help support the weight, since they would provide a component of force in the vertical direction. However, the pressure would always be ρgz, irrespective of the sidewall geometry.
Chet
Yes. But the pressure is force/unit area. To determine that the pressure is ρgz you have to determine the weight of the water bearing on a unit of area. How are you suggesting we show that the pressure is ρgz? You can't just use Bernouilli - he had to work it out from first principles.
AM
AM
Andrew,
What I'm saying is that we are dealing with a student here who is a little confused. Apparently in her course, they have gotten her to the point where she is now comfortable with p = ρgz, by whatever derivation. But if we take her back to p = W/A macroscopically, and she accepts that this can always be used, then, when she tries to apply it to something like my cone example, she is going to get the wrong answer, and then will be more confused than ever. You and I know how all this ties together mathematically, but she is new to the subject and probably doesn't. I feel happy that she has gotten to the point where she accepts p = ρgz. I'm just hoping that she is not motivated to take a step backward.
Chet
Related to Hydrostatics with density and area
1. What is hydrostatics?
Hydrostatics is the study of fluids at rest, specifically focusing on how fluids behave under the influence of gravity and other external forces.
2. How does density affect hydrostatics?
Density is a key factor in hydrostatics because it determines how much mass is contained in a given volume of fluid. This affects the pressure exerted by the fluid, as well as its buoyancy and ability to support objects.
3. Why is area important in hydrostatics?
Area is important in hydrostatics because it is used to calculate the force exerted by a fluid on a submerged object, as well as the pressure at a given point within the fluid.
4. What is the relationship between density and pressure in hydrostatics?
In hydrostatics, pressure increases with depth due to the weight of the fluid above it. This relationship is directly proportional to the density of the fluid, meaning that the higher the density, the greater the pressure.
5. How is hydrostatics applied in real-life situations?
Hydrostatics has many practical applications, such as in designing and building dams, ships, and other structures that must withstand the pressure of fluids. It is also used in calculating the buoyancy of ships and submarines, as well as in hydraulic systems and pumps.
