Hydroxl Ion radius, binding energy and vibrational frequency
In summary: If not, you can probably find information about it on the internet.The potential energy of the point-charge is just the electric potential energy of the charge at that point. The potential energy of a sphere is the sum of the electric potential energy of all the charges inside the sphere.
spaderdabomb
49
The Hydroxl Ion (OH-) may be considered as a bound state of O2- and a proton. Treating the O2- ion as a nucleus of charge +8 with the electrons homogeneously distributed in a sphere of radius b, determine approximately the position of the proton, the hydroxl binding energy and its vibrational frequency.
Vibrational energies E=(n + 1/2)hbarω n = 0, 1, 2...
E = hv=hc/λ where v is the vibrational frequency
This was a test question and I got 1/20 points on it lol. So my attempt was pretty futile. There may be different methods you can use to solve this problem. One of my questions is what exactly the binding energy is. I thought it would just be the ground state vibrational energy but I could be wrong.
The binding energy is the ground-state energy of the proton in the potential well generated by the oxygen atom (neglecting motion of oxygen and the influence of the proton on the electron distribution). It is negative.
The (positive) vibrational energy has to be lower in magnitude than the binding energy, otherwise the molecule would break apart instead of oscillating.
Ok well I'm still not sure how to go about calculating the binding energy then. I understand how to get the vibrational energy but the binding energy and the distance between the two atoms is still confusing me.
I guess I know that the binding energy is at a minimum in potential energy which would correspond to the distance between the two molecules, but I just don't even know where to start. Help specifically on the math and calculations would be appreciated.
I have no idea how you want to determine the vibrational energy without knowledge of the binding energy.
I don't think you are supposed to solve the Schroedinger equation for that potential, so it is probably sufficient to calculate the minimum of the potential energy, using the given charge distribution.
Do you know how the potential of a point-charge looks like? The potential of a sphere?
I am sorry to hear that you did not receive a high score on this test question. As a scientist, it is important to understand and analyze the information provided in the question to come up with a proper solution.
The binding energy of the Hydroxl Ion refers to the energy required to separate the O2- ion and the proton, essentially breaking the bond between them. This energy can be calculated using the Coulomb's law and the distance between the two particles.
To determine the position of the proton, we can use the concept of center of mass. Since the O2- ion is treated as a nucleus of charge +8, the center of mass will be closer to the O2- ion. Therefore, the proton will be located at a distance less than b from the center of the O2- ion.
To calculate the vibrational frequency, we can use the formula E = hv = hc/λ, where h is Planck's constant, c is the speed of light, and λ is the wavelength. The vibrational energy can be calculated using the formula E = (n + 1/2)hbarω, where n is the quantum number and ω is the vibrational frequency.
Overall, solving this problem would require the use of various concepts and equations from physics and mathematics. It is important to carefully analyze the given information and use appropriate formulas to arrive at a solution.
Related to Hydroxl Ion radius, binding energy and vibrational frequency
1. What is the Hydroxl Ion radius?
The Hydroxl Ion radius is the distance from the center of the Hydroxl Ion to its outermost electron. It is typically measured in picometers (pm) or angstroms (Å).
2. How is the binding energy of Hydroxl Ion determined?
The binding energy of Hydroxl Ion is determined by the electrostatic attraction between the positively charged hydrogen atom and the negatively charged oxygen atom. It is also affected by the presence of neighboring atoms and molecules.
3. What factors affect the vibrational frequency of Hydroxl Ion?
The vibrational frequency of Hydroxl Ion is affected by the strength of the bond between the hydrogen and oxygen atoms, the mass of the atoms, and the shape and symmetry of the molecule.
4. How does the Hydroxl Ion radius affect its chemical properties?
The Hydroxl Ion radius affects the molecule's polarity and ability to form hydrogen bonds with other molecules. It also influences the molecule's reactivity and solubility in different solvents.
5. What is the relationship between the binding energy and vibrational frequency of Hydroxl Ion?
The binding energy and vibrational frequency of Hydroxl Ion are inversely proportional. As the bond between the hydrogen and oxygen atoms becomes stronger, the vibrational frequency increases, and the bond becomes more difficult to break.
