Hyperelastic problems - analytical solutions?
  • Thread starter Thread starter FEAnalyst
    Analytical
The discussion centers on the search for analytical solutions to hyperelastic problems in solid mechanics, particularly for simple geometries and loads like tension and compression. The participant has successfully found hand calculations for nonlinear materials but struggles with hyperelasticity, seeking literature that includes exemplary stress/strain calculations. They express interest in the neo-Hookean model due to its simplicity but note a lack of resources that provide practical examples. Recommendations for books and manuals focused on hyperelastic materials are requested, especially those that include calculation examples similar to those found in older Polish texts. The conversation highlights a gap in accessible literature for analytical solutions in hyperelasticity, particularly for more complex loading scenarios.
FEAnalyst
TL;DR Summary
Are there analytical solutions for simple solid mechanics problems (e.g. bending of a beams, torsions of shafts, internal pressure in pipes) involving hyperelastic material?
Hi,
I have recently become interested in analytical solutions of various advanced solid mechanics problems, mostly nonlinear ones. I consider simple geometries and loads (like bending of beams, torsion of shafts, or internal pressure in pipes), but for nonlinear materials. I have learned that hand calculations for such cases are possible even when plasticity or creep conditions become involved. The results are in very good agreement with FEA. However, there is still at least one major issue left that puzzles me - hyperelasticity. Are there any analytical solutions at all for such materials (considering simple geometries and loads)? If so, what kinds of problems can be solved this way - only axial tension/compression or maybe also bending, torsion etc.? And where to look for such solutions? So far I have not been able to find anything concrete, but I am missing literature where examples of this type would be presented.
I'm not sure which hyperelastic material model could be used for calculations like that but I assume that if they are possible at all then neo-Hookean material might be the right choice as it seems to be the simplest model, with only two constants involved: https://en.wikipedia.org/wiki/Neo-Hookean_solid
Thank you in advance for any help.
Hi, I never dealt directly with hyperlastic materials, but a nice book that I came across some years ago had a chapter dedicated to hyperelasticity. The book is this one:
Notes on Continuum Mechanics
It is very dense from the mathematical point of view, but it might help! It presents not only the model you mentioned, but also other ones.
Thank you for the recommendation, I was not familiar with this publication. However, what I need is a book with exemplary stress/strain calculations involving hyperelastic material models. And all the books I've found so far (including this one) only discuss the material models themselves. I am looking for a source that will be equivalent to what helped me hand calculate problems involving plasticity and creep. Those were old Polish books in a "collection of tasks" form. I don't know if such publications are available in English and if they cover hyperelasticity as well but maybe there are also some textbooks focusing on theory but featuring occasional exemplary calculations (like a typical "mechanics of materials" or "solid mechanics" guide). Maybe I should look for something more practical, like a manual for the design of hyperelastic (polymer/rubber) components (such as gaskets).
Anyway, I will be very grateful for any other recommendations. It may not be possible to solve more complex loading scenarios (bending, torsion) involving hyperelastic materials but it should be possible to solve at least simple tension/compression analytically. I guess that it's just a matter of obtaining stress-strain curve for uniaxial tension from material model's constants. The problem is that those models use description based on strain energy density instead of directly providing stress-strain relationship.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
