Hyperelasticity - Mooney-Rivlin stress equation
  • Thread starter Thread starter FEAnalyst
    Stress
The discussion focuses on the discrepancies between two equations derived from the Mooney-Rivlin potential for hyperelastic materials. The first equation from a 1989 Polish book yields incorrect values, while a revised version from a more recent article aligns with finite element analysis results. Participants speculate that a typo in the book may be responsible for the error, particularly regarding the constants used in the equations. They also note that the definitions of the constants C10 and C01 should be consistent across sources, but discrepancies arise when applying the equations. The conversation highlights the importance of accurate derivations in hyperelasticity modeling.
FEAnalyst
TL;DR Summary
What makes one of the equations for stress based on Mooney-Rivlin potential wrong?
Hi,
as I've mentioned in this thread, I am looking for analytical solutions for simple loading cases involving hyperelastic materials. It turned out that the literature on rubber part design might actually be a good lead. In a rather old (written in 1989) Polish book "Gumowe elementy sprężyste" ("Rubber Elastic Parts") by M. Pękalak and S. Radkowski, I've found a discussion of calculations for several basic load cases. Most of the formulas there are based on a specific derivation of the hyperelastic potential, but for uniaxial tension, there is also an equation derived from the Mooney-Rivlin potential: $$\sigma_{eng}=2 \left( \lambda - \frac{1}{\lambda^{2}} \right) \left( C_{10}+C_{01} \lambda \right)$$ where: ##\lambda## - stretch ratio, ##\lambda=\frac{L}{L_{0}}##, ##L## - final length, ##L_{0}## - initial length, ##C_{10}## and ##C_{01}## - Mooney-Rivlin constants.
Unfortunately, this equation gives incorrect values, but in the article "Hyperelastic Constitutive Modeling of Rubber and Rubber-Like Materials under Finite Strain" by M.N. Hamza and H.M. Alwan, I´ve found another version of this equation, which gives results that fully coincide with those obtained from FEA: $$\sigma=2 \left( \lambda^{2} - \frac{1}{\lambda} \right) \left( C_{10} + \frac{C_{01}}{\lambda} \right)$$ I don't know what's wrong with this first equation - is there a mistake in the book or is it another form that should be used differently? The textbook says that this first equation gives the engineering (nominal) stress, while the article most likely gives the formula for the true stress. However, the relationship between engineering stress and true stress is: $$\sigma_{true}=\sigma_{eng} \lambda$$ Applying this transformation on the first formula doesn't give the second equation. Does anyone know where the error is?
Hi, are the constants ##C_{10}## and ##C_{01}## defined in the same way in both books?
Made me laugh.
From what you wrote, I would guess that the first equation has a typo:
C01λ instead of C01
Eq. 5.53 of Hyperelasticity Primer by Hacket agrees with your second equation with the stress explicitly identified as the Cauchy Stress.
He also identifies nominal (eq. 5.57) and Second Piola-Kirchhoff (eq. 5.55) stresses which are consistent with the second equation.
https://www.amazon.com/dp/3319732005/?tag=pfamazon01-20
It's strange because the constants should agree:
- in the book: $$W=C_{1} \left( \lambda_{1}^{2} + \lambda_{2}^{2} + \lambda_{3}^{2}-3 \right) + C_{2} \left( \frac{1}{\lambda_{1}^{2}} + \frac{1}{\lambda_{2}^{2}} + \frac{1}{\lambda_{3}^{2}} - 3 \right)$$
- in the article and in the software used to perform FEA for comparison: $$W=C_{10} \left( \lambda_{1}^{2} + \lambda_{2}^{2} + \lambda_{3}^{2}-3 \right) + C_{01} \left( \frac{1}{\lambda_{1}^{2}} + \frac{1}{\lambda_{2}^{2}} + \frac{1}{\lambda_{3}^{2}} - 3 \right)$$
so I replaced ##C_{1}## with ##C_{10}## and ##C_{2}## with ##C_{01}## and yet the results are incorrect when the equation from the book is used. However, when the constants are swapped the equation gives expected values. So maybe it's a mistake in the book.
caz said:
Made me laugh.
Old for a book, it's already yellowed and printed on this type of paper that's not used anymore. I mean, I have books as old as from 1950s but most of them are much newer. Especially when problems like hyperelasticity are considered. For comparison, here are the years in which each of the common hyperelastic material models was developed:
- Arruda-Boyce: 1993
- Marlow: 2003
- Mooney-Rivlin: 1948
- Neo-Hookean: 1948
- Ogden: 1972
- Polynomial: 1951
- Van der Waals: 1984
- Yeoh: 1993
Since you are talking about switching constants to explain things
in Hackett
nominal = λ×(Second Piola-Kirchhoff)= Cauchy/λ2
https://en.wikipedia.org/wiki/Mooney–Rivlin_solid
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
