Hypothesis: Can a photon be predicted where it will hit?
  • Thread starter Arthurz11
  • Tags
    Photon
In summary: Each position measurement in that experiment is independent and nothing to do with...the other position measurement.This is a misunderstanding of what entanglement is. Entanglement is a relationship between particles that allows them to share information even if they are separated by a large distance. In the double slit experiment, the photons are not actually "partners" in the sense that they share information. They are just spatially correlated, which is to say that their positions are related.
Arthurz11
Hi Scholars!The two slit experiment is like studying the fundamentals of Quantum Physics. Anyway, on the two slit experiment, where individual photons are fire one at a time on the 1st screen that has two slits. The photons would either go through both slits, or through the left slit or through the right slit. On the second screen, it's like a photographic plate that captures light. Well, when hundreds of photons have gone through the first screen, the photon goes on to hit on the second screen where eventually an interference pattern will emerge. The photons hits randomly on the second screen but interference still appears. 100% accuracy can be calculated in a group of photon distribution. Hence, using the equation: x=(m * w * L) / d. x=position, m=order, w=wavelength, L=distance between screens, d=separation of slits. This equation is utilized to find out how far apart are bright fringes from the center bright fringe. However, it cannot be done for an individual photon. Now, if someone could predict the future hits on the second screen. What would be the ramifications? It's only a hypothesis but what would happen if this could be done without disturbing the interference pattern. Would that change current theories?
Arthur Hernandez
You are asking "if physical laws did not apply, what would physical laws say about <insert nonsense of your choice>"
Likes sanpkl and bhobba
QM would be dethroned.
Thanks
Bill
Surely this is perfectly possible to do using entangled photons without dethroning QM?
Why do you think bhobba is wrong about that and you are right? Do you know something he doesn't? If so, please state what it is and explain how such a prediction (as discussed in the OP) would not violate QM.
Likes bhobba and StevieTNZ
It's perfectly possible that bobba overlooked the use of entangled photons and was only thinking of the single particle case. It's also possible I'm wrong - that's why I asked a question rather than making a bald assertion. It would be best to let him answer for himself.
I am perfectly aware of such things.
It would be dethroned from the very axioms QM is based on:
https://www.physicsforums.com/threads/the-born-rule-in-many-worlds.763139/page-7
See post 137
Notice the key axiom:
An observation/measurement with possible outcomes i = 1, 2, 3 ... is described by a POVM Ei such that the probability of outcome i is determined by Ei, and only by Ei, in particular it does not depend on what POVM it is part of..
See that key word highlighted. If you could predict the outcome then probability wouldn't enter into it and the axiom would be invalidated and replaced with something else. It may still be valid as some kind of approximation but it would be wrong.
Thanks
Bill
Thanks for the link.
Well, you said to a fellow mathematician that there is a "lot to digest". And so there is, even more so for someone like me who struggles with maths. (I'm working on it - give me time!) I don't have any feel at all for POVMs so I'm not sure whether "in particular it does not depend on what POVM it is part of" is key to the question. If it is perhaps you could say what it means in this specific example?
But we may get there quicker if I just comment on this: "If you could predict the outcome then probability wouldn't enter into it". In my scenario, the first photon is already subject to probability. It hits the screen at a certain, though not predictable, position. If my understanding of entanglement is correct then its partner must hit the other screen in a corresponding place. There doesn't seem to be any denial of probability in this - the pair of particles is subject to the same probability distribution because they are entangled. The fact that the second measurement yields the same positional outcome using a different photon does not undermine the probability principle any more than finding a single electron in the same place twice in quick succession would do.
Whether my understanding of entanglement is correct is another matter.
Please detail that understanding and its applicability to the double slit experiment.
When doing that please take into account forum rules that personal speculative theories are off topic here.
Each position measurement in that experiment is independent and nothing to do with entanglement.
Thanks
Bill
The precise detail isn't the point - don't worry if you don't get the specifics.
The point is right at its foundations QM is probabilistic. If it wasn't and you could actually predict the outcomes of observations such as the position in the double slit experiment, then like classical thermodynamics is to classical mechanics, it would not be a fundamental theory any-more and it would be dethroned.
Thanks
Bill
I was not suggesting that probability can be suspended. What I was suggesting is that probability applies to an entangled pair as a whole so that although the position of the first is probabalistic, that of the second correlates precisely with the first.
But in any case, I've realized where I was going wrong. I was misled by the emphasis on knowing where the second photon will land - which is somewhat suggested by the title of the thread! - and was overlooking the importance of retaining the diffraction pattern. If the OP had been asking just about predicting the position, my idea would have stood, but on thinking about it I'm pretty sure you can't create a diffraction pattern *and* retain the positional entanglement.
What entangled pair?
The double slit has no entangled pair and I specifically mentioned that in my reply.
I have zero idea why you are still going down that path.
Thanks
Bill
Related to Hypothesis: Can a photon be predicted where it will hit?
1. What is a hypothesis?
A hypothesis is a proposed explanation or prediction for a phenomenon or observation. It is a tentative explanation that can be tested through further research and experimentation.
2. Can a photon be predicted where it will hit?
Yes, a photon can be predicted where it will hit using the laws of physics and mathematical models. However, predicting the exact location of a photon is not always possible due to the inherent uncertainty of quantum mechanics.
3. How can a scientist test this hypothesis?
A scientist can test this hypothesis by conducting experiments using a controlled environment and measuring the behavior of photons. They can also use mathematical models and simulations to predict the behavior of photons in different scenarios.
4. What are the potential implications of this hypothesis being proven?
If this hypothesis is proven, it could have significant implications for fields such as quantum computing and telecommunications. It could also lead to a better understanding of the fundamental nature of light and its behavior.
5. Has this hypothesis been tested before?
Yes, this hypothesis has been tested and studied extensively by scientists. However, the results and conclusions are still debated and further research is needed to fully understand the behavior of photons.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
