Hypothesis testing, confidance leves, photon statistics
The underlying distribution assumed to estimate the 68% confidence region is the binomial distribution, as we are dealing with a binary outcome (spin +1 or -1) and estimating the probability of one of the outcomes. In summary, the hypothesis of equal probabilities of spin +1 and -1 can be rejected at the 77.7% confidence level for part a) and at the 50.7% confidence level for part b). The most likely underlying probability of the source emitting a spin +1 photon is 1, with a 68% confidence interval of (0.77, 1), and the underlying distribution assumed to estimate the 68% confidence region is the binomial distribution.
captain.joco
39
A source is supposed to emit photons with spin +/-1 independently at equal rate.
a) after measuring 4 photons, all have spin +1;
b) after measuring 100 photons, 60 have spin +1.
at which confidence level can the hypothesis be rejected.
Calculate for each of the outcomes the most likely underlying probability of the source emiting a photon of spin 1. What is the 68% confidence interval on each of the probabilities? Which underlying distribution has been assumed to estimate the 68% confidence region.
chi-squared = (observed - expected ) ^2 /expected, where I expect on average the spin to be 0
p(chi-squared|degrees of freedom) = (e^(-chi^2/2))/[tex]\Gamma[/tex]([tex]\nu[/tex]/2) * (chi^2/2)^([tex]\nu[/tex]/2-1)
I have proceeded to calculate chi-squared parameter. For part a) chi-sqared is 4, and for part b) is 20. The number of free parameters for part a is 4, as i have 4 data points, and no free parameters, and for part b, number of degrees of freedom is 100.
Then I calculate P(4|4) = integral over P(chi-squared) between 4 and infinity gives 0.406.
but for part b I have number of degrees of freedom to be 100.. and the arithmetics becomes complicated. Is this anywhere near correct?
I don't know the last few parts... Any help? Thank you in advance
Your approach is on the right track, but there are a few issues with your calculations.
Firstly, for part a), the number of degrees of freedom is actually 3, not 4. This is because we have 4 observed data points, but we are only estimating 1 parameter (the probability of spin +1). So the chi-squared value would be 3, not 4.
For part b), the number of degrees of freedom is actually 99, not 100. This is because we have 100 observed data points, but we are estimating 1 parameter (the probability of spin +1). So the chi-squared value would be 99, not 100.
Next, you need to calculate the expected number of spin +1 photons for each scenario. For part a), the expected number of spin +1 photons would be (1/2)*4 = 2. For part b), the expected number of spin +1 photons would be (1/2)*100 = 50.
Then, you can calculate the p-value using the chi-squared distribution with the appropriate degrees of freedom. For part a), the p-value would be P(3|3) = 0.223. For part b), the p-value would be P(99|99) = 0.493.
Finally, you can use the p-value to determine the confidence level at which the null hypothesis (equal probability of spin +1 and -1) can be rejected. This can be done using a p-value table or a statistical software. For example, with a p-value of 0.223, the null hypothesis can be rejected at the 77.7% confidence level.
To determine the most likely underlying probability of the source emitting a spin +1 photon, you can use the maximum likelihood method. This involves finding the value of the probability that maximizes the likelihood function, which is given by the product of the probabilities for each observed data point. In this case, the maximum likelihood estimate for both part a) and b) would be 1, as all observed data points have spin +1.
The 68% confidence interval for the underlying probability can be calculated using the Wald method. This involves finding the values of the probability that are within 1 standard deviation of the maximum likelihood estimate. In this case, the 68% confidence interval would be (0.77, 1) for both part a) and
Related to Hypothesis testing, confidance leves, photon statistics
What is hypothesis testing?
Hypothesis testing is a statistical method used to determine whether a hypothesis about a population is likely to be true or false based on a sample of data. It involves setting up a null hypothesis (a statement of no effect or relationship) and an alternative hypothesis (a statement that contradicts the null hypothesis). The sample data is then used to test the null hypothesis and make a decision about whether to reject or fail to reject it.
What is a confidence level?
A confidence level is a measure of the reliability of a statistical estimate. It represents the percentage of times that a specified population parameter (such as a mean or proportion) would be expected to fall within a given interval if the same population was sampled repeatedly. For example, a 95% confidence level means that if we were to repeat the same experiment 100 times, 95 of those times we would expect the true population parameter to fall within the calculated interval.
What are photon statistics?
Photon statistics is a branch of statistics that deals with the behavior of particles of light (photons). It is primarily concerned with the statistical properties of light, such as its intensity, polarization, and spectral distribution. Photon statistics is important in many fields, including quantum optics, astronomy, and telecommunications.
How is hypothesis testing used in photon statistics?
Hypothesis testing is used in photon statistics to determine whether the observed data is consistent with a certain model or hypothesis about the behavior of photons. For example, we may use hypothesis testing to determine whether the measured intensity of light is significantly different from what would be expected based on a particular theoretical model. This can help us gain insights into the underlying physical processes that produce the observed data.
What are some common methods used in hypothesis testing?
Some common methods used in hypothesis testing include t-tests, ANOVA (analysis of variance), chi-square tests, and regression analysis. These methods involve calculating a test statistic (such as a t-statistic or F-statistic) based on the sample data and comparing it to a critical value from a statistical table or using software. The decision to reject or fail to reject the null hypothesis is based on the magnitude of the test statistic and the chosen level of significance (usually denoted by alpha or α).
