High School (Hypothetical) 6ft hardened-steel cube dropped at 100 meters
  • Thread starter Thread starter DdraigiSun
    Cube Hypothetical
Dropping a 6ft hardened-steel cube from 100 meters would generate significant energy upon impact, calculated using the formula mgh, where m is mass and h is height. The mass can be determined by the cube's volume and the density of steel. This energy can be compared to that of various explosives to gauge the potential destruction caused by the impact. The discussion emphasizes the importance of physics calculations to understand the implications of such a scenario. Overall, the hypothetical situation raises intriguing questions about the destructive power of heavy objects in free fall.
DdraigiSun
During a random conversation with a friend, we got onto the subject of dropping a 6ft cubed cube of Hardened-Steel from the height of 100 meters.
I ended up getting really curious about the energy it would cause, as well as the potential impact/destruction it would cause on the area.
Considering the large weight of the object I'd imagine it'd have a decent result, however, because I'm not particularly great with this stuff I thought that I'd ask people who are actually good at Physics.
You can work this out for yourself. You know the volume of your cube and google will find you the density of steel; this gives you the mass. The energy in Joules released by a mass ##m## falling from height ##h## is ##mgh##. You can compare that with the energy per kilogram released by by various explosives (again, google is your friend) to get a sense of just how destructive the impact might be.
Likes CWatters and russ_watters
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
20K
10K
