Hypothetical Eclipse Calculation
In summary, the conversation discusses the hypothetical scenario of an object the size of a quantum particle causing a total eclipse of a star the size of the sun when orbiting the Earth at a specific distance. It is mentioned that a quantum particle does not have a definite size and further calculations and considerations are needed to accurately answer the question. The concept of diffraction is also brought up as a factor to be considered.
mahonskey
TL;DR Summary
Hypothetical: Approximately how far from earth would a star the size of the sun have to be for an object the size of a quantum particle to cause a total eclipse of that star when orbiting the earth at a distance equal to that from earth to the center of the moon?
Hypothetical: Approximately how far from Earth would a star the size of the sun have to be for an object the size of a quantum particle to cause a total eclipse of that star when orbiting the Earth at a distance equal to that of Earth to the center fro the moon?
Space news on Phys.org
A quantum particle does not have a definite size. You need to either pick an object that does, or just pick a size directly, for your question to be answerable.
Say there is a particle between a star and eyes of an observer
D: diameter of the star
d: diameter of the particle
R: distance from the eyes to the star
r: distance from the eyes to the particle
[tex]D/R=d/r[/tex]
This is the preliminary evaluation with no quantum nor GR effects considered.
EDIT: I would add diffraction, dispersion by air and field of view of an eye to the factors to be considered.
Likes mahonskey
Alright, let's just say an electron. Classical electron radius.
Then you can plug that into the formula given in post #3.
Likes mahonskey
It should be noted that this formula, strictly speaking, is for a single "eye" receiving the light at a point--more precisely, in a region smaller in diameter than the particle. That is not actually true for a single human eye and a particle with a diameter as small as the classical electron radius; the individual light sensors in the human eye are much larger than that. But we could imagine some idealized detector the size of an atomic nucleus, or smaller.
Likes mahonskey
You don't happen to know the smallest diameter detectable by the human eye, do you?
Not off the top of my head, no, but I would guess that if "detectable" means "resolvable by a single cell in the retina, if we attached idealized detectors to it" it's around 1 micron (##10^{-6}## meters), since that's my rough estimate of the size of the cells involved. That's about 9 orders of magnitude larger than the classical electron radius.
If "detectable" means "actually perceivable consciously by the human whose eye it is", the answer is probably 1 or 2 orders of magnitude larger; IIRC a human hair is about 100 microns (1/10 millimeter) wide, and that's a rough proxy for the smallest diameter we can consciously perceive.
Likes mahonskey
For an obstacle comparable in size to the wavelength of light you most definitely need to consider diffraction. And the far field diffraction pattern, at least, includes a bright spot in the middle.
For an obstacle much smaller than the wavelength of light (like an electron), I don't think it would have any material effect at all. It's a bit like asking if you can deflect a tsunami by holding a shield up infront of you. Even if you were strong enough not to get swept off your feet the wave would just wash over you and keep going.
Likes anuttarasammyak
FAQ: Hypothetical Eclipse Calculation
What is a hypothetical eclipse calculation?
A hypothetical eclipse calculation is a scientific method used to predict the occurrence of a solar or lunar eclipse based on astronomical data and mathematical calculations.
How accurate are hypothetical eclipse calculations?
The accuracy of hypothetical eclipse calculations depends on the accuracy of the data and the complexity of the mathematical models used. Generally, they are considered to be highly accurate but can have slight variations due to factors such as the Earth's changing orbit.
What data is needed for a hypothetical eclipse calculation?
The data needed for a hypothetical eclipse calculation includes the positions and movements of the Sun, Moon, and Earth, as well as their relative distances and sizes. This data is collected through observations and measurements made by astronomers.
How are hypothetical eclipse calculations used in scientific research?
Hypothetical eclipse calculations are used in various scientific research fields, including astronomy, astrophysics, and geophysics. They help scientists understand the movements and interactions of celestial bodies and can also be used to study the Earth's rotation and orbit.
Can hypothetical eclipse calculations be used to predict future eclipses?
Yes, hypothetical eclipse calculations can be used to predict future eclipses. By using data and mathematical models, scientists can accurately predict the dates, times, and locations of upcoming eclipses. However, these predictions may change slightly as new data is gathered and more precise calculations are made.
