MHB I<0? Evaluate New Year Challenge Integral
  • Thread starter Thread starter anemone
    Challenge Year
anemone
MHB
POTW Director
Let $$I=\int_{2013}^{2014} \frac{\sin x}{x}\,dx$$. Determine with reason if $I<0,\,I=0$ or $I>0$?
This challenge is one of my top favorite problems that can be cracked using purely elementary method! (Sun):)
Mathematics news on Phys.org
converting to degree we have lower limit around $136.90^\circ$ and upper limit around $193.70^\circ$
now from $136.90^\circ$ to $180^\circ$ degrees $\sin$ is $\ge 0$ and from $180^\circ$ to 1$93.70^\circ$ . it is $\le 0$. They come in the same cycle as difference is 1 radian
integral from $(180-13.70)^\circ$ i.e $166.30^\circ$ to $193.70^\circ$ shall be zero provided denominator is constant. as denominator is decreasing the integral from $166.30^\circ$ to $193.70^\circ$ is positive and adding another positive quantity that is integral from $136.90^\circ$ to $166.30^\circ$ which is positive so sum $I \gt 0$
Thanks kaliprasad for participating.
Your solution is quite ingenious, and please note that the value $136.90^\circ$ should be $136.40^\circ$.
Solution of other:
Split the definite integral into two part, with $a$ being the zero at about $2013.75$, note that we have:
$$\int_{2013}^{a} \frac{\sin x}{x}\,dx>\int_{2013}^{a} \frac{\sin x}{2014}\,dx$$
and
$$\int_{a}^{2014} \frac{\sin x}{x}\,dx>\int_{a}^{2014} \frac{\sin x}{2013}\,dx$$
So adding them up yields
$$\begin{align*}I=\int_{2013}^{a} \frac{\sin x}{x}\,dx+\int_{a}^{2014} \frac{\sin x}{x}\,dx&>\int_{2013}^{a} \frac{\sin x}{2014}\,dx+\int_{a}^{2014} \frac{\sin x}{2013}\,dx\\&>\frac{\cos 2013}{2014}-\frac{\cos 2014}{2013}+\frac{\cos a}{2013}-\frac{\cos a}{2014}\\&>0\end{align*}$$
oops my mistake. false start in 2016.
Please don't worry about it...and it was after all an honest mistake, I understand it completely.:)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
