curiouschris
- 147
I know the basic theory to how a steam turbine works. but I have a gap in my understanding of how the thermal dynamics work.
I'll outline a scenario and detail the bit I don't understand.
simple steam turbine
1/ heat source
2/ boiler
3/ steam jet
4/ impeller
The heat source heats the water in the boiler.
Pressure builds in the boiler
The heated water exits the jet, as the pressure drops the exiting heated water turns to steam.
The steam strikes the impeller which spins.
the spinning impeller is used to do work.
My problem is where does the energy to do the work come from?
The steam strikes the impeller at speed thus as the steam strikes the impeller some of the velocity is transferred to the impeller.
My question is what happens to the heat energy?
When the water exits the jet and changes to steam does the steam lose thermal energy which is converted to kinetic energy?
When the steam strikes the impeller does it lose further heat energy or is only the kinetic energy transferred?
How does one calculate the different thermal energies at different points of the process?
That last one I know would be rather complex, I would just like a general idea it doesn't have to be accurate.
Please ignore thermal losses from thermal conductivity and radiation assume everything is made from a super insulator of some sort.
CC
1/ heat source
2/ boiler
3/ steam jet
4/ impeller
CC
