I am stuck with an f90 module with user-defined operations
In summary: If you want to do scalar multiplication, you will need to definea type "Scalar" and add a procedure to the interface.
gluons
I am writing some code which involves numerical integration of a function on a 3D grid of points. I am defining the type vector to refer to these points, and I am also trying to extend the intrinsic operator * to include scalar and vector multiplication. However, I cannot compile and I don't know how to fix it.
I am having trouble with and without the module, but I think it would be better to make it work as a module. I am not sure how to go about getting this to work, though. This one includes just scalar multiplication:
module modvec
type vector
real, dimension(3) :: x
end type vector
interface operator(*)
module procedure distributive
end interface
contains
function distributive(a,v) result (w)
real, intent(in) :: a
type(vector), intent(in) :: v
type(vector), intent(out) :: w
do i=1,3
w(i) = a*v(i)
enddo
end function distributive
end module modvec
This does not compile in the main or as a module. What am I doing wrong?
Technology news on Phys.org
module modvec
type vector
end type vector
end interface
contains
do i=1,3
w(i) = a*v(i)
enddo
end module modvec
You have created an illegal recursive definition of DISTRIBUTIVE
at the line w(i) = a*v(i).
For your (apparent) task, you don't need a type "Vector".
Nor do you need a module procedure to do multiplication.
Ordinary Fortran facilities permit you to multiply a scalar by a vector,
without the need to overlay an operator (*).
If w and v are defined as vectors, then you can write
w = a*v
and the operations are performed on w(1) thru w(3) and v(1) thru v(3).
Related to I am stuck with an f90 module with user-defined operations
1. What is an f90 module?
An f90 module is a Fortran 90 programming construct that allows for the organization and encapsulation of program components such as variables, functions, and subroutines. It can be used to create reusable code and enhance the structure and readability of a program.
2. What are user-defined operations?
User-defined operations refer to functions or subroutines that are created by the user to perform specific tasks. These operations can be defined within an f90 module and called upon by other parts of the program.
3. How do I use an f90 module with user-defined operations?
To use an f90 module with user-defined operations, you will first need to declare and define the module in your program. Then, you can call upon the user-defined operations within the module as needed in other parts of the program.
4. Can I modify a pre-existing f90 module with user-defined operations?
Yes, you can modify a pre-existing f90 module with user-defined operations by editing the module's declarations and definitions. However, it is important to keep in mind that any changes made to the module may affect other parts of the program that use it.
5. What are the benefits of using an f90 module with user-defined operations?
Using an f90 module with user-defined operations can lead to more organized and readable code, as well as facilitate the reusability of functions and subroutines. It can also help to avoid naming conflicts and improve the overall efficiency of the program.
14K
  • Linear and Abstract Algebra
