I can do algebra, but I can't prove this properly (and formally)
  • Thread starter flyingpig
  • Tags
    Algebra
In summary: This isn't a part of the Base Step. Use this to define S(n) as the sum of the squares of the first n positive integers.Assume that S(1) : \frac{1(1 + 1)(2 + 1)}{6} = 1^2 Which is true(2) Inductive Step,Let n = k + 1S(k+1) : \frac{(k+1)(k + 2)(2k + 3)}{6}1^2 + 2^2 + ... + k^2 + (k + 1)^2 = \frac{k(k + 1)(2k
flyingpig
2,579
Prove that for every integer [tex]n\geq1[/tex], that
[tex]1^2 + 2^2 + ... + n^2 = \frac{n(n + 1)(2n + 1)}{6}[/tex]2. The attempt at a solution
Note that everything after this sentence are what I am going to write in my assignment to hand in.
(1) Base Case
[tex]S(n) : \frac{n(n + 1)(2n + 1)}{6}[/tex]
Assume it is true for n = 1
[tex]S(1) : \frac{1(1 + 1)(2 + 1)}{6} = 1 = 1^2[/tex]
Which is true
(2) Inductive Step, let n = k + 1, then
[tex]S(k + 1) : \frac{(k + 1)(k + 2)(2k + 3)}{6}[/tex]
[tex]1^2 + 2^2 + ... + k^2 + (k + 1)^2 = \frac{k(k + 1)(2k + 1)}{6} + (k + 1)^2[/tex]
[tex]= \frac{k(k + 1)(2k + 1)}{6} + \frac{6(k + 1)^2}{6} = \frac{k(k + 1)(2k + 1) + 6(k + 1)^2}{6}[/tex]
[tex] = (k + 1)\frac{k(2k + 1) + 6(k + 1)}{6} = \frac{k + 1}{6} (2k^2 + 7k + 6) = \frac{k + 1}{6} (k + 2)(2k + 3) = \frac{(k + 1)(k + 2)(2k + 3)}{6}[/tex]
Therefore by Principles of Mathematical Induction, [tex]1^2 + 2^2 + ... + n^2 = \frac{n(n + 1)(2n + 1)}{6}[/tex] is true for all integers [tex]n\geq1[/tex]
Q.E.D
Questions
a) Is it okay to say "all" instead of "every"?
b) Yeah I will try to line it up in my real assignment, but I couldn't figure out how to do it here.
c) DO I have to put that Q.E.D thing to look smart?
d) Did I do it correctly or did I totally embarrassed myself
Ideally you would want to clearly exhibit that your S(k+1) does indeed have the same form as S(k). So I would add at your very end that
Thus if S(k)=k(k+1)(2k+1)/6, then we also have S(k+1)=(k+1)[(k+1)+1][2(k+1)+1]/6. So by induction the statement is true.
(1) Base Case
[itex]\displaystyle S(n) : \frac{n(n + 1)(2n + 1)}{6}[/itex] This isn't a part of the Base Step. Use this to define S(n) as the sum of the squares of the first n positive integers.
[STRIKE]Assume[/STRIKE] Show it is true for n = 1: You don't 'assume' this is true, you 'Show' that it's true.
Which is true
Q.E.D
Questions
a) Is it okay to say "all" instead of "every"? Yes. At least it is here, and off-hand, I can't think of a case where it's not OK. ... but why not use the language used in the statement of the problem?
(c): If your professor wants you to use "Q.E.D.", then use it. I've also seen lowercase q.e.d., as well as QED and qed. Also symbols: □ or ■ . What really makes you look smart is a solid proof.(d): In general the proof looks pretty good, particularly if you're fairly new to doing proofs.
For the inductive step:
Make it clear that you are assuming that your expression is true for n = k and from that you are showing that it's true for n = k+1.
In the problem you posted here, I would write something like:
Inductive Step: Assuming that, [itex]\displaystyle S(k)=\frac{k(k + 1)(2k + 1)}{6}\,,[/itex] show that [itex]\displaystyle S(k+1)=\frac{(k+1)(k + 2)(2k + 3)}{6}\,.[/itex]
Proof:
[itex]\displaystyle S(k+1)=S(k)+(k+1)^2[/itex]
[itex]\displaystyle =\frac{k(k + 1)(2k + 1)}{6}+(k+1)^2[/itex]
[itex]\displaystyle =\frac{(k+1)(k + 2)(2k + 3)}{6}\,.[/itex]
Many, if not most, students have trouble with inductive proofs. They tend to assume the thing that they should be proving. You have done a good job avoiding that here.
Here Sammy is telling you the same thing I said earlier and in another thread.
1) Base Case
Let n =1
Which is true
(2) Inductive Step,
Assume that [tex]S(n) : \frac{n(n + 1)(2n + 1)}{6}[/tex] is true, then let n = k + 1 [This is my inductive hypothesis?]
Q.E.D
Your induction hypothesis is what you assume (after all hypothesis means some sort of guess), i.e. your assumption that S(k)=k(k+1)(2k+1)/6.
So to prove a statement on S(n), you need to
1. Establish the base case, i.e. check S(1).
2. Assume S(k) is true. This is your induction hypothesis.
3. Show that if S(k) is true, then S(k+1) is true.
Guys for my inductive hypothesis, do I need to state that [tex]n \in \mathbb{Z}[/tex] and [tex]n \geq 0[/tex]
n is really just a natural number. instead of worrying about writing n is an element of z greater than or equal to 1, just say it's a natural number.
When you write the beginning part, you should put what S(n) is, 1^2 + 2^2 + 3^2.. n^2
e.g say
Prove that [itex] 1^2 + 2^2 + 3^2.. n^2 = \frac{n(n + 1)(2n + 1)}{6} [/itex]
Then you show it for n=1, like you did.
Now, change your n's to k's. You need to write:
Assume it is true for n=k, that is, assume [itex] 1^2 + 2^2 + 3^2.. k^2 = \frac{k(k + 1)(2k + 1)}{6} [/itex]
Then, for k+1, [itex] 1^2 + 2^2 + 3^2.. (k+1)^2 = \frac{(k+1)(k + 2)(2(k+1) + 1)}{6} [/itex]
Then show it like you did.
I like the QED. My prof used to always write, Therefore, by the PMI, the proof is over.
QED sounds better than "the proof is over" in my opinion.
FAQ: I can do algebra, but I can't prove this properly (and formally)
Why is it important to be able to prove algebraic statements formally?
Formal proofs in algebra provide a rigorous and logical way to show the validity of a mathematical statement. They help to make sure that the conclusions we draw are based on accurate reasoning and not just intuition. Additionally, formal proofs allow us to generalize results and apply them to other problems.
What is the difference between solving an algebraic equation and proving it formally?
Solving an algebraic equation involves finding the value of the variable that makes the equation true. On the other hand, proving an algebraic statement formally requires logical reasoning and mathematical rules to demonstrate that the statement is always true, regardless of the specific values of the variables.
Can you give an example of a formal proof in algebra?
One example of a formal proof in algebra is the proof of the quadratic formula. By using the method of completing the square and the properties of real numbers, it can be shown that the quadratic formula always produces the correct solutions to a quadratic equation.
What are some common challenges in proving algebraic statements formally?
Some common challenges in formal proofs in algebra include keeping track of all the steps and making sure they are logically connected, understanding and correctly applying mathematical rules, and finding the most efficient and elegant approach to proving the statement.
Are there any tips for improving the ability to prove algebraic statements formally?
Practicing regularly, understanding the basic concepts and properties of algebra, and breaking down the proof into smaller, more manageable steps can help improve the ability to prove algebraic statements formally. It can also be helpful to study and analyze well-written proofs to understand their structure and logic.
