I cannot work out constants a and b --
  • Thread starter Thread starter tosingoodnessamao
    Constants Work
The discussion revolves around solving for constants a and b in the equation v = ay + by^2, given specific velocity values at different distances from a surface. Two equations were established based on the velocities at 1.5 mm and 3.0 mm from the surface, leading to a system of equations with two unknowns. Initially, a mistake was made by incorrectly multiplying b by y instead of y^2. After recognizing this error, the user successfully solved for the unknowns a and b. The conversation emphasizes the importance of correctly setting up equations to find solutions in mathematical problems.
tosingoodnessamao
If the velocity v of the air in a boundary layer having a dynamic viscosity of 18 × 10−6
kg/ms is given in terms of the distance y from the surface by:
v = ay + by^2
where a and b are constants, calculate the surface shear stress if at 1.5 mm from the surface
the velocity is 75 m/s, and at 3.0 mm from the surface it is 105 m/s.
I know that a is the shear strain/rate and i need to times it by the dynamic viscosity but i really cannot work out a and b.
* update - realised that I forgot to square the value for y when multiplying by b.
shear stress = (shear strain/rate) x du/dy
75 = (1.5 x 10^-3)a + (1.5 x 10^-3)b
105 = (3 x 10^-3)a + (3 x 10^-3)b
You are given three things:
(1) v = ay + by^2 where a and b are constants
(2) at 1.5 mm from the surface the velocity is 75 m/s
(3) at 3.0 mm from the surface the velocity is 105 m/s.
From these, you should be able to set up two equations with two unknowns and solve them for a and b. Have you tried that?
Likes tosingoodnessamao
Two equations with two unknowns. Have you tried solving them?
Yes finally found the unnowns a and b because initially I kept multiplying b by y rather than y^2 which was my mistake.
Yes I have managed to solve them now I recognised my mistake.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
