I can't seem to understand 1d motion.
In summary, The problem statement is that the student is having trouble relating velocity, acceleration, and displacement vs time while studying for a test. They are given a position vs time function and have attempted to use different equations to find instantaneous velocity, acceleration, and time at which the particle changes direction. They have also noticed that the given equation is in the form of one of the kinematic equations and have made conclusions about the values of acceleration, initial velocity, and time at which the velocity reaches 0. They have also asked for clarification on the correct equations for average velocity and speed.
jllorens
1. The problem statement
I am studying for an upcoming test and I am having a lot of trouble relating velocity, acceleration, and displacement vs time.
Given a position vs time function:
x(t) = 6m - (8m/s)t + (1m/s^2)t^2
I cannot for the life of me understand how to find any instantaneous velocity at any time (t), the acceleration, or any time (t) that the particle changes direction.
Equations that I have been trying to use to determine the information are:
The limit t->0 of Dx/Dt (Instantaneous velocity, change in position over change in time)
The limit t->0 of Dv/Dt (Instantaneous acceleration, change in velocity over change in time)
Or should I be focusing on the kinematic equation:
X=Xi + (Vi * t) + 1/2 At^2
I do not even know where to start. Vectors seem so much easier than this. :(
EDIT: I am going to feel very stupid if the answer is sitting in front of me like I think it is. I just noticed that the equation given to me is in the exact form of one of the kinematic equations, minus the 1/2 in front of A, does that mean that acceleration is just 2m/s^2 (2 * 1/2 * 1m/s^2)? Likewise, is the initial velocity -8m/s? If I am right on about that, the time at which the velocity reaches 0 (changes sign) would be 4 sec?
Hi jllorens,
That's looks right to me; the acceleration is 2m/s^2 and the initial speed is -8m/s.
Yes. You are right.
Thank you for the prompt replies. One more question. I have encountered two equations for average velocity, one of which seems more logical to use. If this is incorrect, I will use the other.
Is the average velocity from t=0 to t=5:
Using the equation for average velocity:
Dx/Dt=Vavg
-9 (position obtained by plugging t=5 into the given equation) minus 6 (position obtained by plugging t=0 into the given equation) divided by 5 sec (Tf) minus 0 sec (Ti) equals -3m/s? (-9-6)/(5-0) = -3
If correct, then the average speed for the same duration is simply the absolute value of said velocity?
No. In average velocity we consider the ratio of total displacement to total time. And in average speed we consider the ratio of total distance covered to the total time.
In the above problem they are not the same.
FAQ: I can't seem to understand 1d motion.
What is 1d motion?
1d motion refers to motion that occurs only along a single axis or direction. It is often represented using a straight line, with an object's position changing over time.
Why is 1d motion important to study?
1d motion is important to study because it is the most basic form of motion and serves as the foundation for understanding more complex forms of motion. It also has many real-world applications, such as in the fields of physics, engineering, and transportation.
What are some common misconceptions about 1d motion?
One common misconception about 1d motion is that an object's speed and velocity are always the same. In reality, speed is the magnitude of an object's velocity, which also includes its direction of motion.
Another misconception is that an object's acceleration is always constant. In reality, an object's acceleration can change over time, resulting in a changing velocity.
How can I better understand 1d motion?
To better understand 1d motion, it is important to familiarize yourself with key concepts such as position, displacement, velocity, and acceleration. Practice solving problems using these concepts and also try visualizing the motion using graphs and diagrams.
What are some real-world examples of 1d motion?
Some real-world examples of 1d motion include a car moving along a straight road, a person walking in a straight line, and a roller coaster moving along a track. These examples can also involve changes in speed and direction, making them more complex forms of 1d motion.
