I can't understand this linear equation at all
The discussion revolves around graphing the linear equation 3x - 6y = 0 and finding its intercepts. The original poster struggles with determining additional points beyond the origin (0,0) and attempts various substitutions for x and y without success. Participants emphasize that the equation is already in standard form and suggest converting it to slope-intercept form to identify the slope and y-intercept. They recommend selecting different x-values to generate additional points for graphing. Understanding how to manipulate the equation correctly is crucial for finding multiple solutions and accurately plotting the line.
xilc
Alright...
3x - 6y = 0, Graph the linear equation, finding it's intercepts.
I've tried solving it by putting 0 in for x / y, and I've also tried putting -2 in for x / y, so that y = 2 when I move it over, and the system for my college homework tells me it's wrong either way. I simply don't get it.
Quite obviously, if I try to solve it, I get 0,0. However, I have no idea how to get any other problem solution at all... If I put 0 in for x or y to simply get one variable, it ends up being y = 0, or x = 0... But it's telling me I have to graph multiple points. How would I do this?
you have the equation of a line going thru the origin 0,0 so now can you see what the slope of the line is?
Also can you see other points that might be on the line say pick x=2 then what is y?...
It might help to put the original equation for the line into standard form,
y = ax + b
From this, you are able to determine the slope, a,and the y-intercept, b
You can also generate points and plot the line.
y = ax + b
It's already in standard form, what are you talking about?
y = mx + b is slope intercept...
Ax + By = C is standard form, and it's in standard form already...
Just convert your equation to intercept form. Using that you can graph by just knowing two points. Intercept form is x/a + y/b=1
xilc said:
Alright...
So the line goes through the point (0, 0) (and give both x and y intercepts)
When you put -2 for x, you get -6- 6y= 0
You get 6y= -6. That does NOT give y= 2. Try again.
Well, yes, a line is determined by two points. One of those points is (0, 0). To get another point put in any value of x you like. x= -2 works fine but you have to solve the equation for y correctly!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
