I designing a modulo-49 counter?
In summary: MOD-8 counters.21. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.22. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.23. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.24. Use a 3-bit binary counter to create a MOD-8 counter.25. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.26. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.27. Use a 2-input
EvilSpock
Design: MOD-49 counter with only 54LV163 binary counters
(54LV163 is a 4-bit synchronous binary counter)
4-bit counter = 2^4 = modulo-16
OK, I'm not exactly sure how to combine lesser modulo-N counters to create larger modulo-N counters.
I know they multiply; like 2 MOD-16s can make a MOD-256, I just don't how to implement that...what would this look like?
Thank you for your question. To create a MOD-49 counter with only 54LV163 binary counters, you will need to use a combination of counters and logic gates. Here is one possible solution:
1. Use two 54LV163 counters in cascade to create a MOD-256 counter.
2. Use a 3-bit binary counter to create a MOD-8 counter.
3. Use a 6-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
5. Use a 7-input AND gate to combine the outputs of the MOD-256, MOD-8, and MOD-8 counters.
6. Use a 3-bit binary counter to create a MOD-8 counter.
7. Use a 7-input AND gate to combine the outputs of the MOD-256, MOD-8, MOD-8, and MOD-8 counters.
8. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
9. Use a 3-bit binary counter to create a MOD-8 counter.
10. Use a 5-input AND gate to combine the outputs of the MOD-256, MOD-8, MOD-8, MOD-8, and MOD-8 counters.
11. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
12. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
13. Use a 3-bit binary counter to create a MOD-8 counter.
14. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
15. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
16. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
17. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
18. Use a 3-bit binary counter to create a MOD-8 counter.
19. Use a 2-input AND gate to combine the outputs of the MOD-256 and MOD-8 counters.
20. Use a 2-input AND gate to combine the outputs of the MOD-256
Related to I designing a modulo-49 counter?
What is a modulo-49 counter?
A modulo-49 counter is a type of digital counter used in electronics and computer hardware to count up to 49. It is designed to reset itself to zero after reaching the count of 49, making it useful for a variety of applications such as clock generators, frequency dividers, and data transmission.
How does a modulo-49 counter work?
A modulo-49 counter works by using a series of flip-flops, which are electronic circuits that can store a binary value of either 0 or 1. Each flip-flop represents a binary digit, and as the counter counts up, the flip-flops change their binary values accordingly. When the count reaches 49, the counter resets itself to zero and starts counting again.
What are the advantages of using a modulo-49 counter?
One of the main advantages of using a modulo-49 counter is its ability to easily divide frequencies. Since 49 is a prime number, it can create unique and non-overlapping output frequencies when used as a frequency divider. Additionally, the counter can be easily cascaded to create larger counters with higher counting abilities.
What are some common applications of a modulo-49 counter?
Modulo-49 counters are commonly used in electronic devices that require accurate timing and counting, such as digital clocks, watches, and calculators. They are also used in communication systems, where they can be used to synchronize data transmission and manage signal frequencies.
What are some design considerations when creating a modulo-49 counter?
When designing a modulo-49 counter, it is important to consider the clock frequency, as well as the propagation delay of the flip-flops used. The counter should also be designed to have a synchronous reset mechanism to ensure accurate counting. Careful analysis of the circuit design is necessary to ensure proper functionality and avoid potential errors.
