I desperatley for science fair
In summary, the student attempted to build a bridge using Popsicle sticks but was unable to because of uncontrollable variables. After researching other possible ideas, the student decided to use origami structures but found that they were not up to par. The student is currently looking into a more scientific approach to building a bridge.
shannnono17
Over the summer, to go into Chem I Honors, students at my school have to complete a science fair project. I had decided to do something with bridge structure, and nobody- not my adviser or my teacher- told me what a terrible idea i had. I originally had planned to make mini models with actual construction materials, but after realizing that t was impossible to control all variables in this situation, I had to reconsider. However, it is too late to completely change my idea because my procedure was somehow given the go-ahead (and a 95/100). I then considered using Popsicle sticks to build the bridges, and to have a set number of Popsicle sticks so that the structure was the only thing that changed. Then upon a little research I realized that this project was on a 6th grade level, and would not be acceptable considering how big a grade this is.
I was thinking about something with aerodynamics and bridge structure, but I am having a lot of trouble finding specific ideas on the subject. I desperately need hemp with this project.
What are some questions I can start with in this field? What type of experiment would be acceptable for this topic? How can I involve bridge structure in a high school honors class level science fair project?
Welcome to PF!
Your choice of words help or hemp was interesting.
When I first read it I thought drugs? then no the OP must have meant rope then no I think the OP meant help.
So thinking help, have you looked into using origami structures for your bridge? or even folding paper in a certain way?
https://www.google.com/search?q=ori...3GtHF8gHUpoGQBg&ved=0CCoQsAQ&biw=1238&bih=636
Next there's the famous Tacoma Bridge video where the wind at the right speed introduced oscillations that built up and destroyed the bridge prompting the use of simulations of bridges before building them.
and more info on it:
http://en.wikipedia.org/wiki/Tacoma_Bridge
Alternatively you might consider building a bridge and have a fan blow across it to recreate the Tacoma failure and then show how you might mitigate it.
And a reference for building model bridges:
http://www.garrettsbridges.com/build-it/
In addition to what jedishrfu (wow what a name) said, you can build multiple bridges that are the same in in most ways, but differ slightly.
example: 1 bridge has thick trusses, another has thin trusses.
1 uses super glue, 1 uses wood glue.
etc
try and predict which bridges will work the best and why (try to use a scientific thought process)
then put some weights on the bridge (film it in case they fail) and observe which bridge works the best.
The key to this project succeeding would be a sound hypotheses based on some science, even if the hypothesis is not correct.
The Chem Honors class doesn't require a science fair project that is...chemistry based?
You could use a similar idea and glue two items together and measure the tensile strength of the glue based on the material properties.
You could go further and measure the tensile strength of cured glue when it is exposed to various chemical agents (water, acetone, spray paint, etc) and show what reactions are occurring which change the results of your experiment.
Also, I agree that you could make the bridge project work for a high school level. What differentiates this from the "weeee! We are building a bridge!" project to one that may get a decent grade is the level of scientific effort you put in. As the others have said, make a controlled experiment, form a hypothesis, conduct the experiment, and analyze the data.
Another thought for modeling is to use laser pointers attached to the bridge and shining on some piece of paper
to show change of position or deformation or rotation by how the pointer changes when you put stress on the structure.
Related to I desperatley for science fair
1. What is a science fair?
A science fair is an event where students showcase their science projects and experiments to a wider audience. It is an opportunity for students to apply scientific principles and showcase their curiosity and critical thinking skills.
2. How do I choose a project for the science fair?
Choosing a project for the science fair can be a daunting task. Start by thinking about your interests and what you are curious about. You can also look for inspiration from everyday problems or current scientific issues. Make sure your project is feasible and can be completed within the given time frame.
3. What are the important elements of a science fair project?
A good science fair project should have a clear research question, detailed methodology, reliable data, and a thorough analysis of results. It should also have a visually appealing display and a clear explanation of the scientific principles involved.
4. How can I make my science fair project stand out?
To make your science fair project stand out, you can try to choose a unique topic, use creative and eye-catching visuals, and present your project in a clear and concise manner. You can also add a personal touch by sharing your personal experiences and insights during the project.
5. What are the benefits of participating in a science fair?
Participating in a science fair can have many benefits. It can improve your critical thinking and problem-solving skills, enhance your understanding of scientific principles, and boost your confidence in presenting and communicating your ideas. It can also open up opportunities for scholarships, internships, and future career paths in the STEM field.
  • STEM Academic Advising
