I don't understand a symbol used in this question
  • Thread starter warfreak131
  • Tags
    Symbol
In summary, the problem involves deriving the equation I=(m(g-Rα)R)/(|αfriction|+α) from an experiment where a mass is dropped from a rotating wheel attached to a string. The radius of the wheel is given as R and the experiment is clamped to a table. The question of why the absolute value of αfriction is used remains unanswered.
warfreak131
188
I have to derive the equation:
[tex]I=\frac{m(g-R\alpha)R}{|\alpha_{friction}|+\alpha}[/tex]
What is [tex]|\alpha_{friction}|[/tex] and how do i find it? And why do I use the absolute value of it? The experiment was that we had to measure the angular velocity of a rotating disk and we had to measure how much the speed went down due to friction. But in that case, it would just be the regular alpha.
EDIT: I managed to derive it. But the question of why do we use the abs value still stands.
You will have to explain the set-up better. It looks possibly like a wheel on a flat surface that is given an angular acceleration by having a weight (mg) tied to the wheel edge drop. But that is just a guess.
AM
wow, how the hell did you manage to guess that right :)
Perhaps you could just give us the setup of the experiment. I am just guessing at this point. I still don't understand exactly where the friction term is coming from.
AM
You guessed it right
There is a wheel that rotates. We attached a string to it's axle and a weight was attached to the string. We dropped the mass, that unwound the string, caused the axle to start spinning, and caused the disk to accelerate.
Ok. Well I didn't guess it quite right since I thought the mass was tied to the rim.
Is the axle mounted on something? Does the wheel roll along the surface as the weight drops or does it just spin on the axle? It appears from the equation that the moment of inertia is about an axis a distance R from the centre of mass of the wheel.
Again, can you give us the whole problem? In particular: is R the radius of the wheel? What is the radius of the axle?
AM
http://img196.imageshack.us/img196/3564/35005168.png
R is the radius of the wheel, and the whole device is clamped to the table
Is R the radius of the wheel or the axle? You will need the radius of both the wheel and axle.
AM
R is the radius of the wheel, the instructions on my lab didnt say the R of the axle was necessary. and even though i appreciate the help, i had to hand in the work due to time constraints
FAQ: I don't understand a symbol used in this question
What do the symbols in this question mean?
The symbols in the question are likely mathematical or scientific symbols that have specific meanings. It would be helpful to provide a specific example of the symbols in question so that they can be explained in the context of the question.
Can you explain the meaning of a certain symbol in simpler terms?
Absolutely! As a scientist, it is my job to communicate complex ideas in a way that is easily understandable. Please provide the symbol in question and I will do my best to explain it in simpler terms.
Where can I find a reference for the symbol used in this question?
You can try searching for the symbol in a scientific or mathematical reference book, or using an online search engine. If you are unable to find a reference, I would be happy to assist in explaining the meaning of the symbol.
Can you provide an example of how the symbol is used in a different context?
Sure, I can give you an example of how the symbol is used in a different equation or formula. This may help to clarify its meaning and how it is used in various contexts.
What is the proper way to use this symbol in a scientific or mathematical equation?
The proper way to use the symbol will depend on the specific equation or formula in which it is being used. It is important to understand the meaning and function of the symbol in order to use it correctly. It may also be helpful to consult a scientific or mathematical style guide for guidance on proper usage.
