I don't understand an approximation in an expression in stat. mech.
In summary, the dude seems to be saying that if he replaces the l's in the equation with x's, then the sum approximates the integral as T gets bigger and bigger. He is not able to do the change of variables to get rid of the l's outside the exponential, so he's not sure if the approximation is good or not.
fluidistic
264
Hello guys, I fail to understand a mathematical approximation I see in a solved exercise.
The guy reached a partition function of ##Z=\sum_{l=0}^\infty (2l+1) \exp \left [ -l(l+1) \frac{\omicron}{T} \right ]## and he wants to analyze the case ##T>> \omicron##.
He states that with the change of variables ##x=l(l+1)\frac{\omicron}{T}##, ##Z\approx \frac{T}{\omicron} \int _0^\infty e^{-x}dx##.
I really don't understand this last step.
Sum becomes integral. The change of variables.
Making the change of variables, I understand that the sum transforms into an integral and I also understand why the limits of the integral are 0 and infinity (because l goes from 0 to infinity and thus x too).
I am unable to perform the change of variables and get rid of l's outside the exponential.
I'd appreciate if someone shed some light. Thanks.
I think the l's get sucked into what becomes dx since the derivative of l(l+1) is 2l+1.
Likes fluidistic
Notice that once you insert the substitution, ## Z=\sum_{l=0}^\infty (2l+1) \exp \left [ -l(l+1) \frac{\omicron}{T} \right ]##, ## =\sum_{l=0}^\infty (2l+1) \exp [-x] ##.
Then see that ## dx=(2l+1)\frac{\omicron}{T} ##.
So, ## 2l+1=dx\frac{T}{\omicron} ##.
Since ##T>>o ## the integral is a good approximation, since it is the limit as ## l(l+1)o/T \to 0 ##.
Putting this all together, ## Z = \int_{l=0}^\infty \frac{T}{\omicron} \exp [-x] dx ##.
Likes fluidistic
Thank you guys. I missed the dx part indeed.
I understand your confusion and I will try to explain it in a clear way. First, let's recall the definition of a partition function in statistical mechanics. The partition function Z is defined as the sum over all possible states of a system, each state multiplied by its Boltzmann factor (e^(-E/kT)). In this case, the states are represented by the quantum number l, and the energy is given by E = l(l+1)ω, where ω is a constant related to the energy levels of the system.
Now, let's focus on the change of variables that the person did in the exercise. By substituting x = l(l+1)ω/T, we are essentially changing the variable from l to x. This is a common technique in integrals, where we try to simplify the expression by changing the variable to something more manageable.
So, what happens to the sum when we make this change of variables? Well, let's write it out explicitly:
Z = ∑(2l+1)e^(-l(l+1)ω/T)
= ∑(2l+1)e^(-x)
= ∑(2l+1)dx/dl e^(-x)
= ∑(2l+1)dx/dl e^(-x)dx
= ∑(2l+1)e^(-x)dx
= ∫(2l+1)e^(-x)dx
In the last step, we have replaced the sum with an integral, since we are now integrating with respect to x instead of l. However, we still have the (2l+1) term outside the integral. But, if we look closely, we can see that (2l+1) is just a constant, and it can be taken out of the integral. Therefore, the integral becomes:
Z = (2l+1)∫e^(-x)dx
Now, we can evaluate this integral, since it is a simple exponential integral. The result is:
Z = (2l+1)(-e^(-x)) + C
= -(2l+1)e^(-x) + C
But, we are not interested in the constant C, since it will cancel out when we divide Z by Z. So, we can ignore it and just focus on the exponential term. If we substitute back x = l(l+
FAQ: I don't understand an approximation in an expression in stat. mech.
1. What is an approximation in statistical mechanics?
An approximation in statistical mechanics is a simplified mathematical representation of a complex system. It allows for easier analysis and calculation of properties and behavior of the system.
2. How is an approximation used in statistical mechanics?
An approximation is used in statistical mechanics to make predictions about the behavior of a system, such as the average energy or temperature, without having to consider every individual particle or molecule in the system.
3. What are the limitations of using approximations in statistical mechanics?
Approximations in statistical mechanics can introduce errors and may not accurately represent the behavior of a system in certain situations. Additionally, some approximations may only be valid under certain conditions or for specific types of systems.
4. Can an approximation be improved upon in statistical mechanics?
Yes, an approximation in statistical mechanics can be improved upon by using more advanced techniques or by including additional factors in the calculation. However, these improvements may also come with increased complexity and computational cost.
5. Are there any real-world applications of approximations in statistical mechanics?
Yes, approximations in statistical mechanics are widely used in various scientific fields, such as physics, chemistry, and engineering, to study thermodynamic systems, phase transitions, and other complex phenomena. They also play a crucial role in the development of new materials and technologies.
