I don't want to get scammed by the electronic store
  • Thread starter flyingpig
  • Tags
    Electronic
In summary, a voltage is a measure of the potential difference between two terminals, and by connecting a wire, an E-field is created within that wire. Having a higher voltage means that more energy is available to drive electrons from one terminal to the other. It can also be more efficient in some cases, such as reducing power consumption and allowing for smaller conductors. The choice of voltage depends on the application and the need for a certain voltage to power specific devices. Higher voltage can also reduce losses in power transmission.
flyingpig
2,579
A voltage - potential difference- is really just a measure of how badly electrons want to go from one terminal to the other. By connecting a wire, we create an E-field within that wire - the only path.
Now my problem is, I used to think a battery - a source of voltage - is source of energy that drives these electrons charges from one end of the terminal to the other. So what does having a higher volt battery mean? Isn't it more inefficient?
If I some light bulbs and it only need 7V, but if I insert a 8V will the bulb go brighter?
Yeah, that seems reasonable.
Um, well I think you answered your question of what having a higher voltage means in your above statement of what potential difference is.
Yes, well as you well know, the bulb will get brighter, because it has a certain resistance, and if you put a higher voltage across that resistance, the current drawn will be larger, and the total power dissipated will be greater (leading to a brighter bulb). That is just Ohm's law.
Typically you choose your voltage based on the application. For instance, maybe you need a certain voltage to "turn on" an LED in a circuit. Or maybe you're using some sort of chips that only function with voltages in a certain range (this is determined by the type of digital logic used in those chips). There has been a move towards so called "low power" chips that do use lower voltages to reduce power consumption, and make it so that switching the signal on a line from "low" to "high" (in the digital logic sense) requires a lower overall voltage swing.
What could be the advantage of having a higher voltage? Well, if you are powering a device or load that has a fixed power consumption*, raising the voltage will mean lowering the current drawn. That will allow you to get away with smaller conductors saving on costs. If powering off batteries, it also means those batteries will last longer. This is also similar to the reason why they use really high voltage transmission lines to transmit electrical power. The power plant produces a fixed power, and increasing the voltage lowers the current, leading to fewer Ohmic (resistive) losses over the transmission lines.
*Obviously a light bulb/resistor is not an example of something that uses a fixed power
EDIT: I threw a bunch of random examples in this post to illustrate that there are any number of reasons why you'd pick a given voltage in a given situation.
FAQ: I don't want to get scammed by the electronic store
How can I tell if an electronic store is legitimate?
One way to determine the legitimacy of an electronic store is by researching their reputation. Look for reviews and ratings from previous customers. You can also check if the store has any certifications or affiliations with reputable organizations.
What should I look for when buying electronics to avoid being scammed?
Be cautious of deals that seem too good to be true, as they may be a sign of a scam. Additionally, check for the store's return and warranty policies, as well as their contact information. It's also a good idea to compare prices with other reputable stores to ensure you are getting a fair deal.
Should I be wary of online electronic stores?
While there are many legitimate online electronic stores, there are also many scams. It's important to do your research and be cautious when making purchases online. Look for secure payment options and be wary of sites that ask for personal information or payment outside of the website's platform.
Are there any red flags to watch out for when shopping at an electronic store?
Yes, there are several red flags to watch out for when shopping at an electronic store. These include unclear or inconsistent product descriptions, lack of customer reviews, and an unprofessional or poorly designed website. If you feel unsure or uncomfortable about a store, it's best to avoid making a purchase.
What should I do if I think I have been scammed by an electronic store?
If you believe you have been scammed by an electronic store, contact your bank or credit card company immediately to report the issue and dispute any charges. You can also file a complaint with the Federal Trade Commission or your local consumer protection agency. If possible, gather any evidence or documentation of the scam to support your claim.
