I found a *useful* method to calculate log(a+b), check it out
In summary, the conversation discusses a method for approximating logarithms using the formula Log(a+b) = Log(2) + Log(SQRT)(a*b). It can work with any base as long as it is the base for all three logarithms in the formula. The results will be closer to the real values the bigger (a+b) is. The conversation also includes notes on using natural numbers, real numbers, and the difference between Brazilian and American notation. The conversation also touches on the relationship between arithmetic and geometric mean.
guifb99
So, I found this method, I don't think I was the first to, though, but I don't see any post related to this anywhere on the internet, so maybe there's a slim chance I was the first? Anyway, it doesn't really matter. The method does not give the precise result, only approximations, but I find it really useful, since when I have to use logarithms, I only work with approximations. Here it is:
It works with any base you choose, as long as it is the base for Log(a+b), Log(2) and Log(SQRT)(a*b) at the same time
See the "equals to" symbol as an "is approximate to" symbol
Also, "(SQRT)" means "square root of", quite obvious
And since Log(SQRT)(a*b) is (Log(a*b))/2, then
Log(a+b) = Log(2) + (Log(a*b))/2
And since (Log(a*b))/2 = (Log(a) + Log(b))/2, then
Log(a+b) = Log(2) + (Log(a) + Log(b))/2
In base 10, Log(2) is approximately 0,3, so
Log(a+b) = 0,3 + Log(SQRT)(a*b) in base 10
***IMPORTANT***
The bigger (a+b) is, the closer the results will be to the real values
If a>b
The smaller (a-b) is, the closer the results will be to the value
If b>a
The smaller (b-a) is, the closer the results will be to the value.
Example:
If you use this to find Log(11) and you want to use only natural numbers, you should use "6" and "5" for "a" and "b", it will not work if you use, instead, "10" and "1" for "a" and "b"
Also, "a" and "b" can be any REAL number to make this work, I don't know if this works with complex numbers, but I'm guessing it doesn't.
Anyway, I hope this helps you guys, any questions just ask me :)
Likes Battlemage!
I'm brazilian so we use commas in cases like Log(2) = 0,3
But for americans, you can see the 0,3 as a 0.3 ;)
So you basically approximate the arithmetic mean by the geometric mean?
Likes fresh_42
I don't even know what a geometric mean would be, I only know the basics of logarithms... I'm 15 years old
Your notation in the last term on the right is confusing. Most people would normally write a square root of a*b as SQRT(a*b), not make it look like (SQRT) "times" (a * b).
The reason behind your IMPORTANT notes is this:
Suppose ##\frac{a + b} 2 = \sqrt{ab}##
This equation is equivalent to the one I quoted above, assuming that a + b > 0 and ab > 0 for the logs to be defined.
Square both sides: ##\frac 1 4 (a^2 + 2ab + b^2) = ab##
Multiply both sides by 4: ##a^2 + 2ab + b^2 = 4ab##
Add -4ab to both sides: ##a^2 - 2ab + b^2 = 0##, or ## (a - b) = 0##
With the assumptions I listed above, all of the steps are reversible, so if a = b, then ##\frac{a + b} 2## is exactly equal to ## \sqrt{ab}##, and the logs of both expressions would be equal as well.
Likes Battlemage!
Sorry, I'm new to this forum, didn't even know we could use these "uncommon outside the mathematic language" characters such as √ here, but thinking about it now, it makes sense that we would have these as this forum is basically about physics and mathematics. Anyway... thanks for explaining that, now I know why (a–b) must be close to zero in order to make this approximation works
Writing it again...
a>b ⇔ Lim(a–b)→0Log(a+b) ≈ Log(2) + Log√(a⋅b)
See https://www.physicsforums.com/help/latexhelp/.
I used \frac{a + b} {2} to make the fraction and \sqrt{ab} to make the square root. Put a pair of # characters at the beginning of the expression, and another pair at the end, and your browser will turn them into nicely formatted math.
This is really cool. Thanks.
Related to I found a *useful* method to calculate log(a+b), check it out
1. How does the method calculate log(a+b)?
The method calculates log(a+b) by using a mathematical formula that takes into account the values of a and b. This formula is based on logarithmic properties and allows for an efficient and accurate calculation of log(a+b).
2. Can the method be used for any values of a and b?
Yes, the method can be used for any values of a and b as long as they are both positive numbers. This method is applicable for both large and small values of a and b, making it a versatile tool for logarithmic calculations.
3. How accurate is the method compared to other methods of calculating log(a+b)?
The accuracy of the method depends on the precision of the input values and the implementation of the mathematical formula. In general, this method is considered to be highly accurate and can produce results comparable to other commonly used methods for calculating log(a+b).
4. Are there any limitations to using this method?
There are some limitations to using this method, such as the requirement for both a and b to be positive numbers. Additionally, the method may not be suitable for extremely large or small values of a and b, as it may lead to loss of precision in the calculation.
5. How can I use this method in my research or work?
This method can be used in various fields of science and mathematics where logarithmic calculations are required. It can be implemented in computer programs or used manually for quick and accurate calculations. It is important to understand the limitations and assumptions of the method before using it in any research or work.
  • Linear and Abstract Algebra
