I found another easier way of solving y=x^k.
  • Thread starter Ambrose 2014
In summary, this conversation discusses the proof of the Exponential Equation. The example provided gives tools and tricks for finding the squared or cubed value of any number, such as 57^2=A and 1234^3. The formula involves using the digits of the number, represented by n and L, and manipulating them to find the answer, represented by A. The conversation also touches on using decimals in this process and how to generalize the formula using binomial theorem. The three methods of using binomial theorem are also discussed.
Ambrose 2014
The proof of the
For starts this proof and example will give you tools and tricks to find any number squared or cubed etc like 57^2=A and even 1234^3
So x^2=A
Where A is the Answer
and x is the #
now think of n being every digit except L where L is last digit
Ex: 57 n=5,L=7 1234 n=123,L=4
now (n+L)=x is not true So what do you do since L is separated as a one digit so times n by 10 would give you (10n+L)=x since taking
x-L=ny where y is a constant coefficient stating that x's digits are involved as the maxed # of digits so if n's digits -1digit gives 1 less digit then x were when x-L would give n digits with 0 on the end as the x # of digits which want coefficient of y would give a value times n give a number with n digits with 0 10 would.
Ex: 57=(5+7)=12
so to make this true move 7 over
57-7=5+7-7
50=5y
so to make this a true equation 5 has to be multiplied by 10 as y
50=5•10
50=50
Ex2: 1234=10n+L
1234=(10•123)+(4)
1234=1230+4
1234=1234
So if x=10n+L
therefore x^2=(10n+L)^2=A
Which is the same as say A=(10n+L)(10n+L)=
100n^2+(10nL)+(10nL)+L^2=100n^2+20nL+L^2
now let's get the answer first use a calculator and square 57
giving 3249 and done by my equation gives the same answer proven by the Example below
Ex: A=100n^2+20nL+L^2
where n=5 and L=7
A=100(5)^2+20(5)(7)+(7)^2
A=100(25)+20(35)+49
A=2500+700+49
A=3249
Eureka! I know this is one example so I'll do one more
345,679^2=A
Which 34,567=n and L=9
A=100n^2+20nL+L^2
A=100(34,567)^2+20(34,567)(9)+81
now your thinking that's to large of a number to square so you take 34,567^2
3456=n,L=7
100(3456)^2+20(3456)(7)+49
and to make easier repeat
3456^2
n=345,L=6
100(345)^2+20(345)(6)+36
so you can keep going down
345^2
n=34,L=5
100(34)^2+20(34)(5)+25
And again a final time
34^2
n=3,L=4
100(3)^2+20(3)(4)+16
100(9)+20(12)+16
900+240+16
1156
Put back into the previous part as 34^2
100(1156)+20(170)+25
115,600+3,400+25
119,025
which we do again
For 345^2
100(119,025)+20(2,070)+36
11,902,500+41,400+36
11,943,936
and for 3,456^2
100(11,943,936)+20(24,192)+49
1,194,393,600+483,840+49
1,194,877,489
And for 34,567^2
100(1,194,877,489)+20(311,103)+81
119,487,748,900+6,222,060+81
119,493,971,041
which is proven by Putting 345,679^2= giving 119,493,971,041
what about decimals like 0.25^2 or 0.39^2 how can you calculate the number you add a new thing to the theorem which will give us a decimal number so for first 0.25^2=.0625 which reminds me of 25^2=625 and for .39^2=.1521 which reminds me of 39^2=1521. Therefore for both these answers I see that if I take the # of decimals place and move it to the left until there's a whole I can use the exponential formula then after evaluating I have to move it 4 spaces right so it would be for squared #'s with two decimal places would be taking exponential formula answer and divid by 10^4 but in this proof we have to create general so now we'll look at 3 and 4 decimal places like .025^2 or .0025^2 which evaluate to .000625 and .00000625 which we see would be for putting two decimal placed # which would be evaluate as a whole then divided by 10,000 or 10^4 and for three decimal placed # would evaluate as a whole # then divid by 1,000,000 or 10^6 and four decimal placed # which would be evaluate as a whole # divided by 100,000,000 or as 10^8 which if we write in groups to find unknown variable to make this equation true as the # to divid and = 10^d were d is amount of decimal places moved.
10^4=10^d1
10^6=10^d2
10^8=10^d3
we're d1=2,d2=3,d3=4
10^4=10^2
10^6=10^3
10^8=10^4
Where we take out 10^ by doing the log function
Log(10^4)=Log(10^2)
Log(10^6)=Log(10^3)
Log(10^8=Log(10^4)
Which gives
4=2
6=3
8=4
by divid the right would give a constant of 2
2=2
2=2
2=2
Which proves that by evaluating the decimal # by moving d decimal places to the left until it's a whole # and putting the whole # though the exponential formula to get a answer divid by 10^2d will get the value of the decimal # squared
Ex: a).45^2 and b)0.0003^2
a) A=100n^2+20nL+L^2/10^2d
n=4,L=5,d=2
A=100(4)^2+20(4)(5)+(5)^2/10^2(2)
A=100(16)+20(20)+25/10^4
A=1600+400+25/10,000
A=2.025(10^3)/10^4
A=2.025(10^-1) or .2025
b) A=100n^2+20nL+L^2/10^2d
n=0,L=3,d=4
A=100(0)^2+20(0)(3)+(3)^2/10^2(4)
A=0+0+9/10^8
A=9/10^8
A=9(10^-8) or 0.00000009
This part of the exponential formula
proven by using binomial theorem
First starting with what we know as (10n+L)^2/(10^d)^2 which can be generalized by
(10n+L)^k/(10^d)^k or (10^kd)
(The true Exponential Theorem)
like I said the the Exponential can proven by a similar Binomial theoremIs the Summation of the theorem which is different from the normal binomial theorem that you do 10n^k
Which is the reason for this to be different. For starts theirs three ways of using Binomial Theorem
1. Pascals Triangle shows what the coefficients are and where to put them
Ex: (10n+L)^3/10^3d
1 1
1 2 1
1 3 3 1
so coefficients are 1, 3,3,1
So from summation we see that 10 and n have same exponent
10^3n^3+10^2n^2L+10nL^2+L^3
then put in coefficients
1000n^3+300n^2L+30nL^2+L^3
2. Factorials which were written where the summation is as
(n!)/(n-k)!(k!) which find each of the coefficients.
Ex: (10n+L)^3/10^3d
Where n! is the exponent of 3
(3!)/0!(3-0)!=1
(3!)/1!(3-1)!=(3•2•1)/1•2•1=3
(3!)/2!(3-2)!=3
(3!)/3!(3-3)!=1
so the Coefficients are 1,3,3,1
now down what we know from the summation
Put in coefficients
3. This way has no name it's
a technique which is hard to explain except by variables so let's do an example:(10n+L)^3/10^3d
So we start with putting down what we know from the Summation
1 2 3 4
so the reason for #ing them since the phase stats that n's exponent of k times the value of last variables coefficient divid by # of section
(k)(c)/s(#)=s(#+1)
where for the first assume 1•1/1
1 1 2 3 4
1 (10n)^3+(10n)^2L+10nL^2+L^3
1 1 3 3 1
The ones do not have to be involved it's there to show why the coefficient is one
1 2 3 4
1 3 3 1
Which is written as
1000n^3+300n^2L+30nL^2+L^3.
So this is my Exponential Theorem
(10n+L)^k/(10^d)^k
or
(10n+L)^k/(10^kd)
Mathematics news on Phys.org
Ambrose 2014 said:
The proof of the
How is this an improvement over multiplying 57 by 57 or 1234 times 1234 times 1234?
I realize that you're doing more than just squaring or cubing numbers, but the explanation seems very long winded for doing something that can be done more quickly using plain old arithmetic.
Ambrose 2014 said:
So x^2=A
and x is the #
Ex: 57=(5+7)=12
Don't write stuff like the above. 57 ##\neq## 5 + 7. Instead, say that you're adding the digits.
57-7=5+7-7
Don't write the above in mathematical symbols. Anybody reading this would think you're nuts, since 57 - 7 = 50, not 5.
Ambrose 2014 said:
50=5y
Just solve for y by dividing both sides by 5. This results in y = 10.
Ambrose 2014 said:
50=5•10
50=50
Ambrose 2014 said:
Ex2: 1234=10n+L
1234=(10•123)+(4)
1234=1230+4
1234=1234
So if x=10n+L
where n=5 and L=7
A=100(25)+20(35)+49
A=2500+700+49
A=3249
345,679^2=A
A=100n^2+20nL+L^2
3456=n,L=7
3456^2
n=345,L=6
345^2
n=34,L=5
34^2
n=3,L=4
100(9)+20(12)+16
900+240+16
1156
115,600+3,400+25
119,025
which we do again
For 345^2
11,943,936
and for 3,456^2
1,194,877,489
And for 34,567^2
119,493,971,041
10^4=10^d1
10^6=10^d2
10^8=10^d3
10^4=10^2
10^6=10^3
10^8=10^4
No. ##10^4 \neq 10^2##, nor are the next two equations true (or even meaningful).
Log(10^4)=Log(10^2)
Log(10^6)=Log(10^3)
Log(10^8=Log(10^4)
No. None of the three equations above is true.
Ambrose 2014 said:
Which gives
4=2
6=3
8=4
These should be a tipoff that you're doing something wrong.
2=2
2=2
2=2
n=4,L=5,d=2
A=2.025(10^3)/10^4
n=0,L=3,d=4
A=0+0+9/10^8
A=9/10^8
Ex: (10n+L)^3/10^3d
1 1
1 2 1
1 3 3 1
Ex: (10n+L)^3/10^3d
(3!)/0!(3-0)!=1
(3!)/2!(3-2)!=3
(3!)/3!(3-3)!=1
Put in coefficients
1 2 3 4
(k)(c)/s(#)=s(#+1)
1 1 2 3 4
1 1 3 3 1
1 2 3 4
1 3 3 1
Which is written as
(10n+L)^k/(10^d)^k
or
(10n+L)^k/(10^kd)
sorry for this horrid proof and I will send you a better one and this formula maybe useless compared to a calculator or the good old grade 3 math way but it's another way of getting to it you see.
sorry for the bad proof I made it up on the spot since I found this formula by experimenting with numbers but that's no excuse so I'll send you a better one later today and yes it is useless compared to Grade 3 algebra way of doing this 452=2025 or today with a calculator or in your head which I do.Also I have language problems so easier wasn't the write word I meant easy
The binomial theorem is a useful way of solving squared numbers in your head more simply, but it's very well known.
here's the better proof
Let's start with the finding of x = 10n+L by writing x in a form that can be expanded to calculate easier.
Let n be all digits except last (ex:x=1234,n=123)
Let L be last digit(ex:x=1234,L=4)
x=Cn+L
where C stands for constant
(x-L)=Cn
therefore
any (number x)-(last digit)=n digits with a 0 as the last digit
x-L=n0
n0=Cn
n0/n=C
10=C
so x=10n+L
xk=(10n+L)k
so what about decimal numbers
(0.25)1=0.25 starts with 2 digits to the right of decimal and ends with 2
(0.25)2=0.0625 starts with 2 digits to the right of decimal and ends with 4
(0.25)3=0.015625 starts with 2 digits to the right of decimal and ends with 6
so therefore
(decimal places of x)(the exponent k)=decimal places of xk
(ex:0.252, (2)(2)=4)
so ((25)(10-2))2=0.0625
hence (25)2)(10-4=0.0625
hence 625/104=0.0625
therefore 0.0625=0.0625
so if you look at the 2nd last line
625/104
you can write this for (0.25)3
as ((25)(10-2))3=0.015625
hence ((25)3)(10-6)=0.015625
hence 15625/106=0.015625
therefore 0.015625=0.015625
so xk/10dk
which is
(10n+L)k/10dk=A
where A is answer
n is all digits except L
L is last digit
d is decimal places moved to make x whole (ex: (0.9056)2=((9056)(10-4))2
k is the exponent
Related to I found another easier way of solving y=x^k.
1. What is the easiest way to solve for y when given y=x^k?
The easiest way to solve for y when given y=x^k is to take the kth root of both sides. This will give you the value of x, which can then be substituted into the original equation to find the corresponding value of y.
2. How does finding an easier way to solve y=x^k benefit me as a scientist?
Finding an easier way to solve y=x^k can save time and effort when working on complex equations. It can also help to better understand the relationship between x and y in the equation, which can be useful in further research and experiments.
3. Are there any limitations to this easier method of solving y=x^k?
Yes, there are some limitations to this method. It may not work for all values of k, and it may not always give an exact solution. It is important to check the solution obtained using this method with other methods to ensure accuracy.
4. Can this easier method be applied to other equations besides y=x^k?
Yes, this method can be applied to other equations with similar forms, such as y=x^m or y=k^x. However, the specific steps may vary depending on the equation.
5. How can I verify that the solution obtained using this method is correct?
To verify the solution, you can plug the values of x and y obtained using this method into the original equation and see if it satisfies the equation. You can also use graphing or other mathematical techniques to check the validity of the solution.
  • General Math
9K
