I have a basic question about inflection points....
  • B
  • Thread starter leright
  • Tags
    Points
In summary, the discussion revolves around the function f(x) = x^(2n) for n greater than 1 and the behavior of its second derivative at x = 0. While it is commonly taught that a second derivative of 0 at a point indicates an inflection point, this is not always the case. In this particular function, the second derivative is always positive, meaning the function is always concave upwards. The question then arises as to why the second derivative is 0 at x = 0, if the function is not changing concavity. It is concluded that further investigation is needed, such as graphing the function, to fully understand the behavior at this point.
leright
1,318
My question involves the discussion in this thread, which I contributed to back in 2009.
https://www.physicsforums.com/threads/point-of-inflection.350149/
My question involves the function f(x) = x^(2n) for n greater than 1. Take f(x) = x^4 for example. You differentiate twice and you get f''(x) = 12x^2. Plug in x= 0 into the second derivative and you get f''(0) = 0. This implies an inflection point at x = 0 as I was taught in my introductory calculus course. However, we all know that f(x) = x^(2n) is a parabola, which does not change concavity, including at x = 0. Is this function an exception to the rule that I was never taught in school?
Thanks for any insight you can provide. God I feel so silly for asking this...this topic came up recently and I recalled the comments I made in the above thread...I guess I never really looked into it.
The definition of an inflection point is where the function changes from concave to convex or vise versa. This means that f'' changes sign. So naturally you will look for them where f''=0. But that doesn't mean they are all inflection points. In fact, the example you are looking at has f'' ≥ 0. So it is not an inflection point.
Thanks fact checker. It is my understanding that a second derivative of 0 implies a change in concavity (for obvious reasons) or constant first derivative, as in a straight line. Those are really the only two possibilities I can think lf. What exactly is happening at x=0 for the function x^4 then? Clearly its first derivative is not constant and it is not an inflection point.
Thanks.
It just seems like there is something deeper going on here. I actually plotted the function in maple and zoomed in and it appears strangely flat in the region around x=0.
No. Where f''>0 it is concave upwards and where f''<0 it is concave downwards. To find inflection points, you look for points where f''=0 so that you can check whether f'' changes sign there. The function you are considering is always concave upwards.
Thanks. I am fully aware of that but my question relates to the behavior of the function at x = 0. If it isn't an inflection point, or constant slope at that point then why is the second derivative 0? That means that the first derivative isn't changing, right? However that clearly is not the case here.
I am guessing that the second derivative of x^4 evaluated at x=0 is actually non-zero. I think the math might just break down. Correct me if I am wrong. Thanks.
It just means that the first derivative is not changing at that very point. It is changing on both sides of that point. You should look at a graph of it.
No. Why would you think that?
If f(x) = x4
f'(x) = 4x3, and
f''(x) = 12x2.
f''(0) = ?
The actual statement is: "A twice differentiable function of one variable is concave upwards on an interval if and only if its second derivative is non-negative there." (Wikipedia, property #6.)
A non-negative quantity can be zero.
Similarly a twice differentiable function of one variable is concave downwards on an interval if and only if its second derivative is non-positive there.
A non-positive quantity can be zero.
Thus, in practical application of the test, the second derivative being non-zero is conclusive: the function is concave upwards or downwards depending on the sign. But the second derivative being zero is inconclusive and further investigation is required: the function could be concave upwards or concave downwards or there could be a point of inflection.
You really should learn to plot these functions, f, f', f'' to see what is going on. Either plot or calculate some values around the point of interest.
Thanks guys. I appreciate your patience.
If f(x) = x4
f'(x) = 4x3, and
f''(x) = 12x2.
f''(0) = ?
I realize that the mathematical result is f''(0) = 0, which implies zero rate of change of the first derivative @ x = 0. However, clearly the function's first derivative is changing at x = 0.
I can easily visualize the plots of x^4, 4x^3, and 12x^2 and I understand the interpretation of the "rules" and why the rules are the way they are. That's not my issue. A second derivative of 0 at a point implies the following: the point is an inflection point [(point where function transitions from being concave up (positive second derivative) to concave down (negative second derivative)] OR in a region where the curve is perfectly straight OR the function is a straight line.
Now, I am a conceptual person. When I think second derivative I think the rate at which the first derivative is changing. When the rate at which the first derivative is changing is ZERO at a given point it is implied that the slope is constant for a brief period. This is not really the case for x^4. The first derivative is 4x^3. Going a infinitesimally small step in either direction of x = 0 for 4x^3 gives a non-zero first derivative. That means that at x = 0 the first derivative is indeed CHANGING. It has a non-zero rate of change at x = 0. Why then is the second derivative zero when evaluated at x = 0 for this function?
I hope I don't come across as being frustrated, because I am not. I really appreciate your help. I'm just trying to clear up some subtle confusion I have.
Thanks. I understand that a second derivative being zero when evaluated at a point is considered both non-negative and non-positive. There is clear ambiguity here. I am just interpreting this as a rate of change of the slope (first derivative). If a second derivative evaluated at a point is zero and it is bot an inflection point then the function must be "flat" about this point. However, it is clear the x^4 does not exhibit this behavior.
Right. But the first derivative is f'(x) = 4x^3. the first derivative at x = 0 is 0 but go an infinitesimally small step to the left or right of x = 0 on the first derivative function and you get a different value of the first derivative. Clearly, then, the first derivative IS changing at x = 0. Do you see my point?
If I through a ball in the air, it is going up; at some point it stops; then it is going down. At the point where it stops, it is not changing. That is even though an infinitesimally small step before or after you get a different value of height. A similar thing is happening to the values of f' at x=0.
If you plot f'(x) = 4x^3 it is clear that its slope is zero at x = 0. But I am just having trouble seeing that characteristic in the plot of f(x) = x^4. What is it about the function x^4 that makes its second derivative zero there? Would that imply that there are two points infinitesimally close together that have the same slope? Is that accurate? I am 100% convinced that you guys are right...I am just having trouble with this small detail.
Maybe I just need to stop thinking about this.
https://math.dartmouth.edu/opencalc2/cole/lecture8.pdf
These notes describe this question at the end. I understand. What I don't understand is the interpretation of a second derivative evaluated to be zero at a point when the function does not have an inflection point at that point. What exactly is happening then at this point? The fact that f''(0) = 0 must describe some property of the function if it doesn't mean it is an inflection point in this case...
No, there is no property. Look at the graph of y = x4. Its shape is similar to that of y = x2.
Given y = f(x) = x4, then f'(x) = 4x3 and f''(x) = 12x2. The second derivative is positive at every x except x = 0. This means that if x < 0, f''(x) > 0, and if x > 0, f''(x) > 0, as well. This also means that the graph of f is concave upwards on both intervals, a fact that is obvious if you look at the graph of y = x4.
Since the concavity doesn't change, there is no inflection point. In this case, f''(0) = 0 has no significance.
A plot of f(x) = x4, f', and f'' for x between -1 and 1 should make this clear. The black line is f, the red is f' and the green is f''. Clearly f becomes very flat at x=0 and curves up at both ends. That is confirmed by the green line, f'', being 0 at x=0 and positive at both ends. It is also clear that the red line, f', has no slope at x=0. f does not have an inflection point at x=0.
I have plotted these functions. I figured it was due to the flatness of x^4 near x=0. Is there a name for a point that has zero f" evaluated at that point but isn't an inflection point? Its significance is the flatness of x^4 compared to x^2 near x=0
No, there is no name for this.
The question has been asked and answered, so I'm closing this thread.
It is called an undulation point.
Likes FactChecker
That's a new one on me...
Related to I have a basic question about inflection points....
1. What is an inflection point?
An inflection point is a point on a curve where the direction of the curve changes from increasing to decreasing or vice versa. It is also known as a point of inflection.
2. How do you find inflection points?
To find inflection points, you can use the second derivative test. Take the second derivative of the function and set it equal to zero. Solve for the x-values, and those values are the inflection points.
3. What is the significance of inflection points?
Inflection points are significant because they represent a change in the direction of a curve. This can indicate a change in the behavior of a system or a critical point in a mathematical function.
4. Can there be more than one inflection point on a curve?
Yes, there can be multiple inflection points on a curve. A curve can have as many inflection points as it has changes in concavity.
5. Are inflection points the same as critical points?
No, inflection points and critical points are not the same. Inflection points represent a change in the direction of a curve, while critical points represent a point where the derivative of a function is equal to zero.
  • Calculus
  • Calculus
