I have no idea how to integrate by parts
In summary, the integration by parts method is easier than the reduction formula, but it can still be difficult to find the antiderivatives.
Juche
36
I don't think anyone in class understands it, we went over it so quick. The only thing I seem to get is that uv - (integral) vdu = (integral) udv. You are supposed to assign u, v, dv and du, but how do you know which is u and which is v? What is the difference between du and dv? Are you integrating the variable in front of du and integrating the unit in front of dv? How do you know which is which? Why does dv sometimes have one of the variables in it and sometimes another?
Beyond that there seem to be so many exceptions and substitutions that I can't begin to get a good handle on it. Is there a website that has basic info for lost people like me?
http://www.math.hmc.edu/calculus/tutorials/int_by_parts/
u is easy to differentiate.
dv is easy to integrate.
(integral)v du is easier to compute that (integral)u dv.
That helps a little but I still need a lot of practice.
suppose you have a function [itex]f(x) = uv[/itex]
it's derivative is given by the product rule:
[itex]\frac{d}{dx}[uv] = u'v + uv'[/itex]
now if you rearrange that to
[itex]u'v = \frac{d}{dx}[uv] - uv'[/itex]
and then take the integral in respect to x of both sides
[itex]\int u'v dx= \int \frac{d}{dx}[uv] dx - \int uv' dx[/itex]
you are left with the equation for integration by parts:
[itex]\int u'v = uv - \int uv'[/itex]
so for a given function of two factors, you can choose either of them to be u' and v... It doesn't matter...
Though generally you want to make u something simple to integrate and v something that becomes simpler after differentiation.
For example [itex]\int \ln(x) dx[/itex], you should pick u' = 1 and v = ln, had you reversed those selections, you would be left with the exact same problem... meaning you still have to integrate ln(x).
The only "exception" to that rule of thumb, is that sometimes the integral will repeat on the other side:
[itex]\int f(x) dx = g(x) - \int f(x) dx [/itex]
In which case you add the righ integral to the left side and divide by the coefficient (in this case 2).
If you forget the formula, just know that it can be derived from the product rule.
Sometimes, it's even easier to do it directly like:
[tex]\int f(x)g'(x)dx=\int [\frac{d}{dx}f(x)g(x)-f'(x)g(x)]dx[/tex]
Just do a lot of practice problems.
Also there usually aren't many ways to choose u and v -- if you don't know, try them all!
Hurkyl's right,there aren't many possible combination of chosing u & dv.The problem appears in the moment when u tried them all and none goes to a result...
For example:
[tex] \int \frac{\sin x}{x} dx [/tex]
for 2 possible combinations and
[tex] \int \frac{e^{2x}}{x+6}\tan x \ dx [/tex]
for a bunch of 6 combinations...
Daniel.
is the uv - (integral) vdu method the same as the reduction formula? If not then what is the reduction formula?
What is the end goal of integration by parts? Is it to find the area bounded by the two functions? How do you know when you've simplified it?
That reduction formula (i've never heard this expression b4) is it somehow related to recurrent integrals...?Like sequences of integrals..?
The "end goal" is to find the antiderivatives among "elementary" functions...
Daniel.
That hopeless u,v, du,dv mysticism..
It has never taught any students anything, I strongly advise you to read Galileo's post.
Related to I have no idea how to integrate by parts
1. What is integration by parts?
Integration by parts is a technique used in calculus to evaluate a definite or indefinite integral where one function can be easily integrated, but the other cannot. It involves breaking down a complicated integral into simpler parts and applying the product rule of differentiation.
2. When should I use integration by parts?
Integration by parts is typically used when the integral involves a product of functions, such as when integrating a polynomial multiplied by a trigonometric function or an exponential function.
3. How do I know which function to differentiate and which to integrate?
The general rule of thumb is to differentiate the function that becomes simpler after being differentiated. This means that the function should eventually lead to a smaller or simpler integral. However, sometimes trial and error may be necessary to determine which function to differentiate first.
4. What are the steps for integration by parts?
The steps for integration by parts are as follows: 1) Identify the two functions in the integral, 2) Choose which function to differentiate and which to integrate, 3) Apply the product rule of differentiation, 4) Simplify the integral as much as possible, and 5) Repeat the process if necessary until the integral can be evaluated.
5. Are there any tips for making integration by parts easier?
One tip for making integration by parts easier is to choose the function to differentiate based on its algebraic complexity. Another tip is to choose a function to differentiate that becomes simpler after multiple differentiations, such as an exponential or trigonometric function.
