I have some questions about upper limit
  • Thread starter jwqwerty
  • Tags
    Limit
Therefore, any subsequence of {Sn} will have a limit of -∞. So, it is always possible to find a subsequence whose limit is -∞.
jwqwerty
43
upper limit is defined as:
lim sup(Sn) = sup E , where {Sn} is a sequence of real numbers and E is the set of all subsequential limits of {Sn}.
Then if sup E = +∞, why is there a subsequence of {Sn} whose limit is +∞?
Also, if sup E= -∞ is there a subsequence of {Sn} whose limit is -∞?
Mathematics news on Phys.org
From the definition. Slightly restating what you wrote, E is the set of limits of subsequences of {Sn}. This means that some subseqence has a limit of +∞.
If sup E = -∞, then every subsequence must have this as a limit. Think about it this way: if the largest value in some set is -∞, there's no way to have any smaller (i.e., more negative) values for limits.
FAQ: I have some questions about upper limit
What is the definition of an upper limit in scientific terms?
An upper limit refers to the maximum value that a particular variable, parameter, or quantity can reach in a given system or experiment.
How is an upper limit different from a lower limit?
An upper limit is the highest possible value, while a lower limit is the lowest possible value. They both define the range of a variable or parameter but in opposite directions.
How do scientists determine the upper limit of a specific variable?
Scientists use various methods such as experimentation, mathematical modeling, and statistical analysis to determine the upper limit of a variable. They also take into consideration factors like physical limitations and theoretical constraints.
Are there any risks associated with reaching or surpassing an upper limit in an experiment?
Yes, there can be risks associated with exceeding an upper limit in an experiment. It can lead to unexpected and potentially dangerous consequences, such as equipment failure or harm to the subject of study.
Can an upper limit change over time?
Yes, an upper limit can change over time. As our understanding and technology advances, the upper limit of a particular variable may increase or decrease, allowing us to push the boundaries of what was previously thought possible.
