I have some questions about wavepackets.
  • Thread starter dsdsuster
In summary, wavepackets are a superposition of infinitely many waves of different momentum, and the group velocity associated with them is not the same as the particle's actual velocity. The distribution of wavenumbers also changes as the wavepacket spreads due to the uncertainty principle.
dsdsuster
30
Hi there
I have some questions about wavepackets. So from my understanding, they are usually a superposition of infinitely many waves of different k (different momentum). However, we can also extract a group velocity that is supposed to correspond to the classical velocity? This group velocity is going to just be a number, with no uncertainty, while the particle's actual velocity has some uncertainty corresponding to the uncertainty in k, the wave number. So what is the group velocity physically if it is not the particle's actual velocity?
I have another separate question about spreading of wavepackets. We typically use some distribution A(k) of wavenumbers that does not change with time to generate the wavefunction. Sometimes the distribution A(k) is obtained from integrating the given wavefunction at time=0. When wavepackets spread, the uncertainty in x increases so shouldn't the distribution A(k) of wavenumbers also change based on the uncertainty principle?
THanks for your help!
The group velocity associated with a wavepacket is an average velocity of the wavepacket over some region of space. It is not necessarily the same as the velocity of a particle that might be associated with the wavepacket, but it can still be used to describe the propagation of the packet in space (and time). As for the spreading of wavepackets, the distribution A(k) of wavenumbers does indeed change as the wavepacket spreads, as the uncertainty principle implies that there must be an uncertainty in both position and momentum for any wavepacket. The exact form of the distribution will depend on the particular wavepacket, but in general the uncertainty in position should lead to an increased uncertainty in momentum, and thus a wider range of wavenumbers.
Related to I have some questions about wavepackets.
1. What is a wavepacket?
A wavepacket is a localized disturbance or oscillation in a wave that is composed of a group of individual waves with different frequencies and wavelengths. It can be described as a wave that has a specific shape and is traveling through space and time.
2. How are wavepackets created?
Wavepackets are created when multiple waves with different frequencies and wavelengths interfere with each other. This interference causes the individual waves to combine and form a localized disturbance or oscillation with a specific shape.
3. What are some examples of wavepackets?
Some common examples of wavepackets include sound waves, electromagnetic waves, and quantum mechanical waves. For example, a musical note can be described as a wavepacket of sound waves, while a laser beam can be described as a wavepacket of electromagnetic waves.
4. How do wavepackets behave?
Wavepackets can behave in different ways depending on the type of wave and the environment in which they are traveling. In general, they can undergo dispersion, which is the separation of different frequencies, and diffraction, which is the bending of waves around obstacles. They can also undergo interference, where the individual waves combine to either strengthen or cancel each other out.
5. What is the significance of wavepackets in science?
Wavepackets are important in many areas of science, including physics, chemistry, and engineering. They help us understand the behavior of waves and their interactions with matter, which is essential for developing technologies such as telecommunications, medical imaging, and quantum computing. Wavepackets are also a fundamental concept in quantum mechanics, where they play a crucial role in describing the behavior of subatomic particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
