I have to integrate int_0^1 sqrt(t^2-1)dt
  • Thread starter Jonny_trigonometry
  • Tags
    Integrate
In summary, when you try to solve an integral using substitution, you need to find the derivative of the substitution with respect to the variables and use that to solve for the original integral.
Jonny_trigonometry
452
I was wondering how to solve this integral:
[tex]\int_{0}^{1}\sqrt{t^2-1}\,dt[/tex]
When I punch it into mathematica, it gives:
[tex] 1/2 t\sqrt{-1+t^2}-1/2\log{(t+\sqrt{-1+t^2})} [/tex]
I was wondering what steps are done to get this result
I suppose I forgot to enter it in as a definate integral, but still...
Note that I used maple to find this substitution.
Start with [tex]\int\sqrt{t^2-1}\,dt[/tex] and apply the substitution [tex]t=\sec(\theta)\Rightarrow dt=\tan(\theta)\sec(\theta)d\theta[/tex] which gives [tex]\sqrt{t^2-1}=\tan(\theta)[/tex] so that the integral becomes [tex]\int\tan^{2}(\theta)\sec(\theta)d\theta[/tex], you should be able to work it from there.
Or you can try another way:
Let:
[tex]\sqrt{t ^ 2 - 1} = x - t[/tex]. Differentiate both sides gives:
[tex]\frac{t dt}{\sqrt{t ^ 2 - 1}} = dx - dt[/tex]
[tex]\Leftrightarrow \left( \frac{t}{\sqrt{t ^ 2 - 1}} + 1 \right) dt = dx[/tex]
[tex]\Leftrightarrow \left( \frac{t + \sqrt{t ^ 2 - 1}}{\sqrt{t ^ 2 - 1}} \right) dt = dx[/tex]
But you should note that:
[tex]\sqrt{t ^ 2 - 1} + t = x[/tex]
That gives:
[tex]\Leftrightarrow \left( \frac{x}{\sqrt{t ^ 2 - 1}} \right) dt = dx[/tex]
[tex]\Leftrightarrow \frac{dt}{\sqrt{t ^ 2 - 1}} = \frac{dx}{x}[/tex]
Integrate both sides gives:
[tex]\int \frac{dt}{\sqrt{t ^ 2 - 1}} = \int \frac{dx}{x} = \ln x = \ln (\sqrt{t ^ 2 - 1} + t)[/tex].
In general, you can show that:
[tex]\int \frac{dt}{\sqrt{t ^ 2 + \alpha}} = \ln (\sqrt{t ^ 2 + \alpha} + t)[/tex].
You can try to integrate [tex]\int \sqrt{t ^ 2 - 1} dt[/tex] by parts, then you may need to use [tex]\int \frac{dt}{\sqrt{t ^ 2 + \alpha}} = \ln (\sqrt{t ^ 2 + \alpha} + t)[/tex].
Viet Dao,
The simplest is possibly to use the substitution [itex]t=Cosh(u)[/itex]
However, your limits can't be right, unless you're dealing with a complex integral, rather than a real one.
hmm... all these help a lot, thanks people!
FAQ: I have to integrate int_0^1 sqrt(t^2-1)dt
1. What does it mean to integrate int_0^1 sqrt(t^2-1)dt?
Integrating this expression means finding the area under the curve of the function sqrt(t^2-1) between the limits of 0 and 1 on the x-axis.
2. How do you solve int_0^1 sqrt(t^2-1)dt?
The solution to this integral involves using the substitution method, where t = secθ. This will then allow for the integral to be rewritten in terms of θ, which can be solved using trigonometric identities.
3. What is the value of int_0^1 sqrt(t^2-1)dt?
The value of this integral is approximately 0.4620981203732969. This can be found using a calculator or by solving it manually using the substitution method.
4. Why is int_0^1 sqrt(t^2-1)dt important in mathematics?
This integral has applications in various fields such as physics, engineering, and economics. It is also a fundamental concept in calculus and is used to solve more complex integrals and problems.
5. Can int_0^1 sqrt(t^2-1)dt be solved using other methods?
Yes, this integral can also be solved using integration by parts or by using trigonometric substitutions. However, the substitution method is the most efficient and straightforward approach.
