I heard the ITER could achieve Q = 10, what about the engineering (actual) Q?
In summary, a Q value greater than 1.1 in fusion engineering likely indicates that the fusion problem has been theoretically solved. However, in order for fusion to be economically competitive, a Q value significantly higher than 1.1 may be necessary. The significant investment in projects like ITER suggests that it is a major scientific achievement.
zheng89120
149
If the engineering Q is greater than 1.1 or so, does that mean the fusion problem has been theoretically solved?
I believe so.
The enormous investment alone should have told you that. No-one gets a blank check (15 billion dollars spent so far) just to play with magnets. ITER is as big a deal as the Fermi pile was in its day. Bigger, actually.
When fusion is working with net energy gain, it still needs to be able to compete economically. For that, we'll probably need a Q considerably greater than 1.1
I can confirm that ITER (International Thermonuclear Experimental Reactor) is a major international project aimed at achieving sustainable fusion energy. The goal of ITER is to demonstrate the scientific and technological feasibility of fusion as a viable energy source.
The Q factor, or the ratio of fusion power produced to the power required to sustain the fusion reaction, is an important measure of the efficiency of a fusion reactor. A Q value of 10 means that for every unit of energy put into the reactor, 10 units of fusion energy are produced. This is a significant milestone that ITER aims to achieve.
However, it is important to note that the Q value is not the only measure of success for a fusion reactor. The engineering Q, which takes into account the actual performance and efficiency of the reactor, is also a crucial factor. This value is affected by various engineering challenges, such as maintaining plasma stability, controlling plasma instabilities, and managing the high temperatures and intense radiation within the reactor.
While a high engineering Q value is certainly desirable, it does not necessarily mean that the fusion problem has been completely solved. Fusion is a highly complex and challenging process, and achieving a high engineering Q value is just one step towards realizing a sustainable fusion energy source. There are still many scientific and engineering challenges that need to be addressed before fusion can become a practical energy source.
In conclusion, while a Q value of 10 is a significant achievement for ITER, it is important to continue research and development to improve the engineering Q and address other challenges in order to make fusion energy a reality.
Related to I heard the ITER could achieve Q = 10, what about the engineering (actual) Q?
1. What does Q = 10 mean in relation to ITER?
Q = 10 refers to the energy output of ITER, which is a measure of the energy produced by the fusion reaction compared to the energy required to sustain the reaction. In other words, a Q value of 10 means that for every 1 unit of energy put into the system, 10 units of energy are produced. This is a key milestone for fusion energy research as it indicates the potential for a self-sustaining fusion reaction.
2. Is Q = 10 the ultimate goal for ITER?
While Q = 10 is a significant milestone, it is not the ultimate goal for ITER. The ultimate goal is to achieve a Q value of 15, which would make the fusion reaction self-sustaining and could potentially lead to commercial-scale fusion energy production.
3. How is the Q value of ITER determined?
The Q value of ITER is determined by measuring the amount of energy produced by the fusion reaction and comparing it to the amount of energy required to sustain the reaction. This is a complex process that involves measuring various parameters such as plasma temperature, density, and confinement time.
4. What is the current engineering Q value of ITER?
The current engineering Q value of ITER is not yet known as the project is still under construction. However, simulations and calculations have estimated that ITER will achieve a Q value of 10 once it begins operation in the late 2020s.
5. Can the engineering Q value of ITER be improved in the future?
Yes, the engineering Q value of ITER can potentially be improved in the future through ongoing research and development. This could involve optimizing the design and operation of the fusion reactor, as well as implementing new technologies and materials. However, the ultimate goal of achieving a Q value of 15 may require the development of more advanced fusion technology beyond ITER.
  • Nuclear Engineering
26K
  • General Math
11K
