I in making a boat for a project
In summary, the project is to test different propeller blades on a small boat to see the effect of different designs. The project does not require a boat, but is easier with one. The project is non-trivial and will require a lot of time and effort.
chirag.rk93
There's a project i have to do where i would be testing different kinds of propeller blades on the boat. Its just to test the effect of different blades so nothing has to be all high-tech. Apparently i know how i can make Propeller blades but i have no idea how to make the boat.
I just need to create a small boat as a model for my experiment. I need ideas on how to make one so that i can attach and detach propellers to it to record its varying performance.
I know this sounds like something really weird to ask but any help will be highly appreciated. Try toe xplain stuff as if u were explaining to a high schooler.
Hope i make sense
CHEERS:)
Hope i make sense
CHEERS:)
Do you actually have to make the boat part for the project? Or can you just buy one from a hobby store?
You can't just buy or rent a real boat with a motor? One of the issue with a boat propeller is that it operates within the wake of a boat, so the boat has an effect on propeller design.
@berkeman
see I am not much of boat geek. I have never bought toy boats so i kinda' don't understand how their system works. the thing is if i buy a boat from outside, will i be able to attach and detach home-made propellers or not?
Also, i believe my english is not that great so their might be a misunderstanding in my descriptions. when i say small boat, i mean a small one like an RC boat. Not a big one. Just a small working model.
Very non-trivial. You have to deliver the 'drive' to the propellor underwater. This can be done with a very long straight shaft at a shallow angle over the stern (like the canoes on the Amazon), a 'stern gland' to take a straight drive to a propellor just under the hull or a right-angled drive (like on a regular outboard motor).
These three approaches suit different hull types (for instance, where the rudder goes).
As far as I can see, you should buy / borrow an existing boat with an engine and just stick to making and testing a few of your designs of propellor.
Mind you, if I had to do it, I'd go to the lake or pond where you plan the tests and get chatting to an enthusiast with a boat. He ( I assume) could be very keen and furnish you with details of shaft and thread size for his boat. You could offer him the best version of propellor from your tests, if it works better than his existing one. This approach involves minimum of non-prop work and maximum time for the actual project.
and
"Its just to test the effect of different blades so nothing has to be all high-tech."
Hah! Tell that to a powerboat enthusiast or oil tanker designer! :biggrin:
The pitch of the propellor, the revs and power of the engine and the hull design speed are all vital to match together, if you are to get the best design for each boat.
Just how long do you have for this proj?
btw, was it ever suggested that you might do static tests in a tank with no boat? You can measure force and water speed very easily when everything is within easy reach.
@sophiecentaur
so here it goes. My aim in the project is to find out the distance traveled by a boat in a particular period of time when a) there is a change in diameter of the propellers and b) there is a change in the number of wings of the propellers. So i need to do a bunch of trials attaching and detaching different propellers. now the problem here is that I DONT HAVE A BOAT.
try and help me what sorts of design i can do to conduct an experiment like this finding out the effect of different kind of propellers.
chirag.rk93 said:
@sophiecentaur
I agree with sophiecentaur's point, that you may be better off *without* a boat for these experiments. It would be much more scientific for you to just use a force measuring device (like a spring balance) to measure the force generated by your propellers in still water. A swimming pool or pond would be fine, as long as you can position the propellers far away enough from the bottom and sides so that there is no interaction with the prop's water stream flow.
A HUGE factor in marine propellor design is the Pitch of the propellor. When it is running properly, it will act exactly like a screw, through the water with very little slippage. If it is too coarse or too fine it will just thrash around in the water generating bubbles and no thrust. I should say that is almost the major factor in the choice of design - as long as the blades aren't too long or too short. Number of blades is only a choice between 2 and 3; more than 3 is unlikely to make any difference (or make it worse) - but your project should show that, I suppose.
Ask anyone who has had proper advice about changing their propellor and they will say it was equivalent to a real increase in power.
Presumably your propulsion will be from a 12V motor. Use a meter to check the current - it will give a good indication of the power being delivered. You will need a gearbox to get the revs something like right or the screw may just thrash around uselessly - do some sums and look up marine propellor design on Google to get some ideas. There are many links at all levels of sophistication.
I am even more of the opinion that you need to collaborate with a local enthusiast or your whole time will be taken up in boat construction and design. Else you'll need to buy something (arrrrrgh!).
But it all depends on what the project is for. If it's something that has been suggested by a supervisor then you may be better to re-think and go for the berkeman solution. Not as flashy but it would give some much more worthy results. Why do you want to get into boats all of a sudden?
I want to know who the hell is making a high schooler do this?! If the internet were not around, this wouldn't even BE a learning experience!
@chirag.rk93: Another approach could be to look at the efficiency of the prop design for a given boat. Then you can choose ONE hull type and pitch, and instead of measuring force with a gauge you probably don't have... you could check to see how many revoltions or how much current applied to different prop configurations while maintaining the boat at a constant speed.
To do that, just have water flowing at a steady rate, and try to keep the boat "stationary" (think of a swimming pool that jets water at you against which you swim). An Ohmeter (with the bells and whistles), a couple of fishtanks and you're halfway there.
Related to I in making a boat for a project
1. How do I choose the right materials for my boat?
Choosing the right materials for your boat will depend on several factors such as the type of water you will be using the boat in, the weight capacity needed, and your budget. Generally, lightweight and waterproof materials like marine plywood, fiberglass, and aluminum are commonly used for boat projects.
2. What is the best design for a boat that will be used in rough waters?
The best design for a boat that will be used in rough waters is one with a deep V-shaped hull. This design helps to cut through waves and provide stability. Additionally, having a wider beam can also make the boat more stable in rough waters.
3. How can I ensure that my boat is safe to use?
To ensure the safety of your boat, it is important to follow proper construction techniques and use high-quality materials. It is also essential to conduct a float test before taking your boat out on the water to check for any leaks or stability issues. Wearing life jackets and having proper safety equipment on board is also crucial.
4. How can I make my boat more energy-efficient?
To make your boat more energy-efficient, you can consider using materials that are lightweight and have low drag, such as carbon fiber or Kevlar. Additionally, designing the boat with a streamlined shape and reducing the weight of unnecessary features can also help improve its efficiency.
5. Can I add any special features to my boat project?
Yes, you can add special features to your boat project depending on your needs and preferences. Some common features include a steering system, navigation lights, and storage compartments. However, it is important to consider the weight and potential impact on the boat's performance before adding any features.
  • Other Physics Topics
  • STEM Academic Advising
  • STEM Educators and Teaching
  • Biology and Medical
