I just cant solve for this unknow, could anyone guild me?
  • Thread starter kritbordin
In summary, the conversation is about a problem involving finding unknown variables A and B in the equations 0.32=A+lnB and 0.51=lnA+B. The poster attempted to solve it by taking the exponential of both sides, but made a mistake. They were advised to use a graphical calculator due to the decimal values involved. The poster also made a typo in the title, as they meant to ask for guidance, not gilding or gelding.
kritbordin
I just can't solve for this unknow, could anyone guild me? please
It is a problem about VLE from i already found almost everything cept this 2 unknowns i can't solve I need to find A and B but it seems hard to me or i did something wrong
Original)
(1)-------- 0.32=A+lnB
(2)-------- 0.51=lnA+B
This is what i have so far
(1)---------- exp(.32)=exp(A)+B = 1.377
(2)---------- exp(.51)=A+exp(B) = 1.665
T_T It confused me. - -
you made a mistake when taking exponentials of both sides.
so your equations are:
0.32=A+lnB
0.51=lnA+B
when taking exponentials, this gives:
exp(0.32)=exp(A+lnB)=exp(A)*exp(lnB)=B*exp(A)
can you do the rest now?
Original)
RHS is wrong remember exp(A + B) = exp(A) * exp(B) remember the rules for exponents.
While your manipulations were incorrect even if you do them correctly you still won't be able to solve this algebraically. Seeing as you have decimal values you could try using a graphical calculator to obtain a decimal result.
I'm having trouble deciphering your post title. Did you mean you wanted someone to gild you? geld you?
Oh, now I get it. You wanted someone to guide you.:smile:
FAQ: I just cant solve for this unknow, could anyone guild me?
What is the best approach for solving an unknown variable?
The best approach for solving an unknown variable is to start by identifying what information is known and what is unknown. Then, use appropriate mathematical operations and equations to isolate the unknown variable and solve for it.
What should I do if I am stuck on solving for an unknown variable?
If you are stuck on solving for an unknown variable, try breaking down the problem into smaller, more manageable steps. You can also seek help from a teacher, tutor, or online resources to guide you through the problem.
How do I know if my solution for an unknown variable is correct?
You can check the accuracy of your solution by plugging in the value you found for the unknown variable into the original equation. If the equation is true, then your solution is correct.
What common mistakes should I avoid when solving for an unknown variable?
Some common mistakes to avoid when solving for an unknown variable include forgetting to distribute negative signs, making calculation errors, and not simplifying the final solution. It is important to double-check your work to avoid these mistakes.
Are there any tips or tricks for solving for an unknown variable?
Yes, there are some tips and tricks that can make solving for an unknown variable easier. These include understanding the order of operations, using algebraic properties, and practicing with different types of equations. It is also helpful to constantly review and reinforce your knowledge of basic math concepts.
