I looked all over the internet for this answer, but couldn't find it
  • Thread starter flyingpig
  • Tags
    Internet
In summary: Arc length is just the radius of the circle times the angle it subtends. In polar coordinates, this is just r*theta.
flyingpig
2,579
Can someone actually explain, without using Calculus, why the arclength formula is s = r*theta
I tried doing this in polar coordinates, but I couldn't think about how to do it.
What's the arc length if θ = 2π ? (a complete circle)
I would imagine that it comes from the fact that a circle has a circumfrence of 2pi*r where theta is just 2pi.
Since the radius of a circle is just a special type of arc. This would only work if the arc has a constant radius, but if that changes you have to do summations of of arcs with constant radius. This would eventually lead to the calculus version of making theta into the infinitely small dtheta
2pi*r, where r is the radius, I think I know how you are going to teach it to me, but I am looking for irregular thetas
Oh, come on. Once you've ruled out calculus to do the computation you just back to basic geometry. If the angle is 2*pi (a whole circle) then the length is 2*pi*r. That's the definition of 'pi'. If the angle is 2*pi*x then the length is 2*pi*x*r. This is really just definition of 'angle'. You know this, right? What kind of 'proof' are you looking for?
Can we prove this in polar coordinates?
What do you mean by prove, and exactly what is it you want to prove?
Let's say I draw an arbituary arc of some angle that's not easy to compute and I want to know the arclength of that arc, why is it s = r*theta. The circumference thing gives me intuition why, but doesn't give me the math that proves to me it is.
s = r*θ works for an arc with constant radius, subtending an angle of θ, but that's not very general or arbitrary.
But it isn't obvious to me
What is the definition of the measure of an angle in radians?
pi/180 * angle
No, that's how to convert an angle measured in degrees to radian measure.
The http://en.wikipedia.org/wiki/Radian#Definition" has this in the definition section:
"... More generally, the magnitude in radians of such a subtended angle is equal to the ratio of the arc length to the radius of the circle; that is, θ = s /r, where θ is the subtended angle in radians, s is arc length, and r is radius. ..."
I hope that helps.
You can prove this with a piece of string, a ruler and any circular object using algebra, knowing only that there is some vague relation between the radius of a circle and the radian.
FAQ: I looked all over the internet for this answer, but couldn't find it
What is the best way to search for information on the internet?
The best way to search for information on the internet is to use specific and relevant keywords, use advanced search operators, and to check multiple sources to verify the accuracy of the information.
Why is it important to fact-check information found on the internet?
It is important to fact-check information found on the internet because not all sources are reliable and accurate. With the rise of fake news and misinformation, it is crucial to verify information and ensure its credibility before sharing or using it.
How can I determine if a source is credible?
To determine if a source is credible, you can check the author's credentials and expertise, the publication date, the sources cited, and if the information is supported by other reputable sources. You can also look for any potential biases or conflicts of interest.
What should I do if I can't find the answer to my question on the internet?
If you can't find the answer to your question on the internet, you can try expanding your search to different keywords, checking different sources, or consulting with a professional in the field. You can also try reaching out to online communities or forums for assistance.
How can I contribute to improving the accuracy and reliability of information on the internet?
You can contribute to improving the accuracy and reliability of information on the internet by fact-checking information before sharing it, citing sources, and reporting any misinformation or fake news that you come across. You can also participate in online discussions and provide accurate information and sources to educate others.
