I need a formula, if one exists.
  • Thread starter Tups
  • Tags
    Formula
In summary, the conversation discusses a strategy for placing bets in order to ensure a desired return. The speaker asks if there is a formula that can be used to determine the amount to bet on two options with known odds and desired return. The formula is given as X = G*(1+Ny)/(Nx*Ny-1) and Y = G*(1+Nx)/(Nx*Ny-1).
Tups
Hello, I am not a mathematician and therefore unsure about what or how i should be asking to make it clear about what i am after.
So i think just showing a practical example is best.
If you have two different options for a bet and both are paying over $2 then it is possible to place a certain amount of money on both bets that will not only pay you for your desired return but also pays for the money invested on the losing bet.
E.g
Desired Return = $100
Bet 1 Odds = $5.50
Bet 2 odds = $2.75
If i put on $40 @ $5.50 it’ll return $220,
And if i put $80 @ $2.75 it’ll return $220.
$220 – $120 (both bet amounts) = $100 my desired return.
Just as long as one of these two bets wins.
So what i'd like to know is if there is a formula that could be used to find out the amount to put on the two bets when only the odds and desired return are known?
The trick obviously is that both unknown figures are reliant on knowing what the other one is.
Many thanks.
Mathematics news on Phys.org
When you speak of "odds" you are giving the winning payout (presumably on a $1 bet)? I ask because there is also an Expected payout, i.e. winnings times chance of winning - cost of the bet. I'll assume you are giving the winning amounts which seems to fit your reasoning.
Try a little Algebra: Bet X dollars on the first and Y dollars on the 2nd. Call Px the payoff for the first and Py the payoff for the 2nd.
Outcomes:
Lose both: Net = -(X+Y).
Win 1st Lose 2nd: Net= X*Px-X-Y = (Px-1)X - Y
Win 2nd Lose 1st: Net= Y*Py-X-Y = X + (Py-1)Y
Win both: Net = X(Px-1)+Y(Py-1).
It is easier to work with the Net payoffs for each bet. Nx = Px - 1, Ny = Py -1.
Winning 1 bet yields your Goal amount (G=$100 in your example):
G = Nx *X - Y
G = Ny* Y - X
Solve this system for X and Y:
X = Ny*Y - G --> G = Nx * ( Ny * Y - G) - Y
(Nx Ny - 1)Y = (1+Nx)G
Y = G * (1+Nx)/(Nx*Ny-1)
X = G [Ny*(1+Nx)/(Nx*Ny-1) - 1] = G(Ny + Nx Ny - Nx Ny + 1)/(Nx Ny - 1)
Check!
Given your goal amount G, and the Net winnings on each bet Nx and Ny you would bet the amounts:
and
And If you win one of the two you will net G dollars.
With your example: Nx = $5.50 - $1 = 4.5, Ny = $2.75 - $1 = 1.75, and G = $100.
X = 100(1+1.75)/(4.50 * 1.75 - 1) = 275/6.875 = $40.
Y = 100(1+4.5)/(4.5*1.75-1) = 550/6.875 = $80.
Don't loose too much money!
Thanks Jambaugh. That is very good of you.
And the formula work a treat also.
I'll look forward to going through your workings tomorrow (one too many drinks tonight) and see where i went wrong.
Thanks again and wish you all the best.
FAQ: I need a formula, if one exists.
1) What is a formula?
A formula is a mathematical expression that represents a relationship between two or more variables. It is used to solve problems and make predictions in various scientific fields.
2) How do I know if a formula exists for my problem?
The existence of a formula depends on the complexity of the problem and the available data. Some problems may have multiple formulas, while others may not have a known formula at all. Researching and consulting with experts in the field can help determine if a formula exists for your specific problem.
3) Can I create my own formula?
Yes, as a scientist, you have the ability to develop your own formula to solve a problem or explain a phenomenon. However, it is important to ensure that the formula is based on sound scientific principles and that it is thoroughly tested before being used for any practical applications.
4) Are there different types of formulas?
Yes, there are various types of formulas, including mathematical, chemical, and physical formulas. Each type serves a specific purpose and is used in different scientific disciplines.
5) How do I use a formula?
To use a formula, you must first understand the variables and their relationships within the formula. Then, you can plug in the appropriate values for the variables and solve for the unknown quantity. It is important to follow the order of operations and use proper units when using a formula.
