I need some serious help, really basic physics
In summary, you are trying to design an apparatus which will hit a marble a horizontal distance of from 1.5-1.6m every time. You have to calculate the force you need to hit the marble, but you can't seem to find an equation which works. If it helps any, the mass of the marble is 3.56g and you are using a hammer which is held up on a swivel which swings down and strikes the marble. As well you have to calculate the average horizontal velocity.
kylelomba8
I am trying to design an apparatus which will hit a marble a horizontal distance of from 1.5-1.6m every time. I have to calculate the force I need to hit the marble, but I can't seem to find an equation which works. If it helps any, the mass of the marble is 3.56g and I'm using a hammer which is held up on a swivel which swings down and strikes the marble. As well I have to calculate the average horizontal velocity. I am just not sure where to begin and what to do.
What forces slow down the marble? That would seem to be a key part of this project, eh?
the only force that slows down the marble is gravity, but I cannot figure out how to calculate the force required to make the marble go that distance
No, gravity does not directly slow down a rolling marble. What is the surface that you need to use for this project? There will not be much rolling resistance if the surface is hard and smooth...
http://en.wikipedia.org/wiki/Rolling_resistance
I have actually made it with a golf tee and there doesn't seem to be too much in terms of friction to move the marble
When I asked what surface, I meant what kind of flooring material is it? Concrete, linoleum, wood, carpet, etc.? Since the ball is rolling, friction will likely play a small roll in slowing it down. It will affect how it reacts to the hammer tap and spin-up in the beginning, though.
Yeah I know what you mean, but when i am calculating it, I am looking for the distance it will go before hitting the floor. So it then doesn't really matter what the surface is.
Oohhh! My bad, I misunderstood your original post (OP). I thought the marble was supposed to roll that distance, but now I understand that it needs to fly that distance and hit its first bounce at that distance. Ah.
You calculate the motion using the initial velocity and takeoff angle, just like for any kinematics problem involving projectile motion and gravity. You should be able to calculate the initial velocity from the striking velocity of the hammer and the hammer and ball masses, since it is an elastic collision...
If you already have the swinging hammer set up trial and error looks like a good solution.
FAQ: I need some serious help, really basic physics
What are the basic principles of physics?
The basic principles of physics include the study of matter, energy, motion, and forces. It also involves understanding concepts such as gravity, electromagnetism, and thermodynamics.
How can I improve my understanding of physics?
To improve your understanding of physics, it is important to practice problem-solving and critical thinking skills. Additionally, seeking help from a tutor or attending study groups can also be beneficial.
Can you explain the difference between speed and velocity?
Speed refers to how fast an object is moving, while velocity takes into account the direction of the object's motion. In other words, velocity is a vector quantity, while speed is a scalar quantity.
What is the role of mathematics in physics?
Mathematics is essential in physics as it provides the language and tools to describe and analyze physical phenomena. It helps us understand relationships between different variables and make predictions about the behavior of objects.
How does Newton's Laws of Motion apply to everyday life?
Newton's Laws of Motion apply to everyday life in various ways. For example, the first law (inertia) explains why objects remain at rest or in motion unless acted upon by an external force. The second law (force and acceleration) helps us understand the relationship between force, mass, and acceleration. The third law (action and reaction) is seen in activities such as walking, where the ground exerts an equal and opposite force to move us forward.
