MHB I need the two elements with the greatest volume in a data set
The discussion focuses on calculating the volume and identifying the locations of the two elements with the greatest volume in large data sets represented by pairs of coins and amounts. A formula was provided to calculate the volume for the first data set, yielding a result of 2.04, indicating greater volume on the left side. The user attempted similar calculations for a third example, resulting in a value of 3.09, which suggested a surge in the middle of the data set. The conversation also touched on the potential need for integrals or summations to refine the calculations further. Ultimately, the user found the initial method effective for their needs, expressing gratitude for the assistance.
tunage
I have very large data sets:
coins & amount
i.e. {10 & 11, 9 & 7, 8 & 9, 4 & 5, 3 & 1} graphed would show greater volume to the left side while {1 & 0, 2 & 3, 2 & 1, 4 & 6, 9 & 10} would reflect greater volume on the right, and {1 & 4, 2 & 3, 12 & 10, 4 & 4, 3 & 2} would reflect a surge in the middle of the data set.
I need to calculate the volume and know the location of the two elements that have the greatest volume.
Mathematics news on Phys.org
coins & amount
If I understand your requirements correctly I think the following would be OK.
For the first set $\frac{1\times 10\times 11+2\times 9\times 7+3\times 8\times 9+4\times 4\times 5+5\times 3\times 1}{ 10\times 11+9\times 7+8\times 9+4\times 5+3\times 1}=2.04..$
The 2.04 indicates your "greater volume to the left side".
This may be of interest: http://archives.math.utk.edu/visual.calculus/5/work.2/
Thank you for your response.
I tried it with the 3rd example and I don't see where it would help.
--> (1*1*4+2*2*3+3*12*10+4*4*4+5*3*2)/(1*4+2*3+12*10+4*4+3*2)
ans =
3.0921
But more importantly I need the element location.
Yes, I am pretty sure I need an integral or a summation for the volume but I think I am going to need quadratics for my second max and probably my first.
ans =
3.0921
If your locations are 1,2,3,4 and 5 then a result of 3.09 is pretty much your "surge in the middle".
Still, I'm not sure that what I'm suggesting is what you need.
That is a very interesting math hack.
I am running some test on it now.
Works perfect. It does everything I need it to do. I don't even need the second max because of how the numbers work.
Thank you VERY much!
I think I remember seeing this back in Physics.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
