I need to find the midpoint of ST
  • MHB
  • Thread starter mathdad
In summary: Notice that this is algebraically equivalent to:M_n=\left(\left(1-2^{-n}\right)x_1+2^{-n}x_2,\left(1-2^{-n}\right)y_1+2^{-n}y_2\right)Now, using the fact that:\lim_{n\to\infty}2^{-n}=0We see that:\lim_{n\to\infty}M_n=\left(x_1,y_1\right)=P_1This is the math agreeing with intuition....we just need to use induction to
mathdad
1,283
The coordinates of the points S and T are S(4, 6) and T(10, 2). If M is the midpoint of line segment ST, find the midpoint of line segment SM.
I need to find the midpoint of ST.
I then need to find the midpoint of SM.
Correct?
Mathematics news on Phys.org
Sounds good to me!
Joppy said:
Sounds good to me!
I just love to be right.
Suppose we are given two points in the plane:
\(\displaystyle P_1\left(x_1,y_1\right)\)
\(\displaystyle P_2\left(x_2,y_2\right)\)
The mid-point of the two given points is given by:
\(\displaystyle P_3\left(\frac{x_1+x_2}{2},\frac{y_1+y_2}{2}\right)\)
Now, we will find the mid-point of $P_1$ and $P_3$ to be:
\(\displaystyle P_4\left(\frac{x_1+\dfrac{x_1+x_2}{2}}{2},\frac{y_1+\dfrac{y_1+y_2}{2}}{2}\right)=\left(\frac{3x_1+x_2}{4},\frac{3y_1+y_2}{4}\right)\)
Suppose we consider $P_3$ to be the first mid-point, and $P_4$ to be the second mid-point...which we will label $M_1$ and $M_2$ respectively. What do you suppose is the formula for the $n$th mid-point $M_n$? What would you say $M_n$ approaches as $n$ goes to infinity?
I like the fact that you always reply to my questions but please keep it simple with me. I took precalculus in 1993. It is a long time ago. I have no clue what M_n tends to as n goes to infinity. I am not too familiar with the concept of infinity. I hope to be there someday but for now, please elaborate.
I'm really just asking you a conceptual question here...think about what happens as you find the mid-point of a line segment, then you find the mid-point of the half having the first point as an end-point, and you keep repeating this over and over...where do you think the $n$th mid-point is heading?
Do you have any hypothesis for the formula of the $n$th mid-point $M_n$?
The nth midpoint is heading to 1 or 0.
Imagine you have a piece of string anchored at one end to a sheet of wood. Now you cut away half the string and discard the free end. You do this over and over...and you notice that the free end is getting closer and closer to the anchored end. If we do this an infinite number of times, we can image the free end becoming indistinguishable from the anchored end. So, we should expect (using the labels from my first post):
\(\displaystyle \lim_{n\to\infty}M_n=P_1\)
Now, if you go back to my first post, you should observe that we could hypothesize:
\(\displaystyle M_n=\left(\frac{\left(2^n-1\right)x_1+x_2}{2^n},\frac{\left(2^n-1\right)y_1+y_2}{2^n}\right)\)
Let $n=1$ and $n=2$ and you'll see that it agrees with the mod-point formulas derived in my post.
I know you haven't gotten to the chapter on mathematical induction yet, but using that technique, we can prove the above is true.
\(\displaystyle M_n=\left(\left(1-2^{-n}\right)x_1+2^{-n}x_2,\left(1-2^{-n}\right)y_1+2^{-n}y_2\right)\)
\(\displaystyle \lim_{n\to\infty}2^{-n}=0\)
We see that:
\(\displaystyle \lim_{n\to\infty}M_n=\left(x_1,y_1\right)=P_1\)
This is the math agreeing with intuition. :D
We see that:
Very impressive.
About as simply as I can put it: one half of one half is one fourth! If M is halfway from S to T then half way from S to M is one fourth of the way from S to T.
Thank you everyone.
FAQ: I need to find the midpoint of ST
What is the midpoint of ST?
The midpoint of ST is the point that is exactly halfway between points S and T on a straight line. It is the point where the line is divided into two equal segments.
How can I find the midpoint of ST?
To find the midpoint of ST, you can use the midpoint formula which is (x1 + x2)/2, (y1 + y2)/2. This formula uses the coordinates of points S and T to calculate the midpoint.
Can I find the midpoint of ST on a graph?
Yes, you can find the midpoint of ST on a graph by plotting points S and T and then using a straight edge to draw a line connecting them. The midpoint will be the exact middle of this line.
What is the significance of finding the midpoint of ST?
The midpoint of ST is important in geometry and mathematics as it helps to determine the center of a line segment. It can also be used to divide a line into two equal parts, which is useful in many mathematical and scientific calculations.
Is the midpoint of ST always in between points S and T?
Yes, the midpoint of ST will always be exactly in between points S and T on a straight line. It is the point that divides the line into two equal segments, so it will always be located between the two points.
