I propose some new forums/sub forums
  • Thread starter Stephenk53
In summary, I think adding forums and subforums is a good idea, but we need to be careful about which ones to add and how to structure them.
Stephenk53
121
55
I think we should add the following forums/ sub forums
Psychology
DIY (engineering or similar STEM pursuits)
Safety
I had a few other forum ideas but I can't remember them so I will have to get back to you on them
Likes ISamson and jedishrfu
Stephenk53 said:
we
Sigh.
Likes Bystander, phinds, russ_watters and 1 other person
The problem with adding forums and subdividing forums into finer structure is that seldom will anyone post there. We have to walk a fine line between too many and too few. Our setup is not optimal but works well for now.
I do like the DIY or MakerSpace forum as I think that is a big trend and folks may even post there. I know I would.
The Safety forum, while useful in itself usually is dispersed among our other forums as it comes up so seldom. In general, we moderate posts that may be dangerous and either warn or delete the post if the activity could cause serious harm. One such example that we've seen are some high voltage experiments where tweens are showing off Jacob's ladder constructs where either you could get zapped with a charge of electricity or irradiated with X-Ray emission from the apparatus.
I'm not sure about a Psychology forum as that seldom comes up or it comes up tending toward philosophy which we don't discuss here.
Our primary mission is to help students of STEM subjects learn their topics better.
Perhaps @Greg Bernhardt could chime in here and explain the PF mission better.
This is something I've long considered. I think it's worth discussing. I would use it, at least in terms of DIY around the house :smile:
The other two I think would not be used enough.
Thanks for the suggestions!
Likes CWatters, ISamson and jedishrfu
This issue has been frequently discussed before and the arguments remain basically the same. A subforum only makes sense, if there is a demand for it. A post now and then wouldn't make sense. Another difficulty is, where to stop to partition the forums? Science as a whole is so broad, that it is practically impossible to cover all aspects and realms. Even in the existing categories physics and mathematics there could be easily added a couple of more. Which brings me to the my main argument: psychology isn't really part of our competence. It would open up the door for a lot of nonsense and non scientific personal stories. We already had to ban politics and philosophy, because of that. Contributions there had nothing, I mean absolutely nothing to do with political science and real philosophy. Everybody felt to be invited to publish their own personal opinion as the most valuable contribution to the fields. Those discussions will inevitable end up in arguments, personal attacks and endless themselves repeating statements, usually without the least chance to find a peer reviewed paper supporting them.
As to a DIY forum, the safety aspect - your third point - is actually the reason why it's not there. You won't imagine what people are trying to experiment with. From acids of all kind, over poisonous chemicals, high voltages and currents to unstable building constructions. This would lead to law cases in which someone might be urged to say "But an engineer (chemist, doctor) on PF has said ..." which nobody wants to risk. It would be irresponsible to support such undertakings, because what actually will happen in real life is far above our influence. The only safe safety post would be to warn before those experiments, which we frequently do on a case to case basis. Beside the legal aspect, it is also ethically irresponsible. A go-ahead-but-watch-out is easily typed far away from all consequences, especially those which might cause irreversible injuries. The only valid DIY advice is: CALL A LOCAL EXPERT!
Yes. I've often considered at least starting a "sticky" thread on DIY projects in the engineering forums, but this is what has stopped me. An awfully high percentage of DIY engineering projects are dangerous or illegal. The rules would need to be very restrictive and even then I'm not sure we could make them adequate.
A simple category/example is any line voltage electrical work. It's legal to do your own, but you have to comply with code and in practice that is difficult for a non professional to do. I recently started a thread on a GFCI plug fault in my pressure washer. I re-wired it with, then without a GFCI plug (but on a GFCI curcuit). Then I disassembled the washer looking for the fault, then I gave up and threw it away. I think that because my credentials/level of responsibility is known here my asking was ok(barely) but as a general practice/rule it would not be since other people who are less knowledgeable/responsible could read the thread and think it is ok for them too.
Alright thanks for the replies. I guess that makes sense. If I can remember the other ideas I'll let you know.
Likes berkeman and Greg Bernhardt
btw, many safe DIY projects can be posted in our engineering forums etc as is.
Likes fresh_42
Another remark on psychology.
I remember a couple posts in which kids (from my point of view, not from theirs) had serious problems and sought for help. Those threads had quickly to be closed along with the advice to see a doctor. Fortunately nobody answered, who wasn't aware of his responsibility in such cases. But this was just luck. It is a public forum and you cannot rule out that questionable recommendations or accusations appear nor that they will be discovered in time. With such a topic you get quickly into situations, which eventually might be life threatening. A general rule only to discuss science won't be read by desperate people.
Likes Evo
Yeah, I have actually done that before, although some of my ideas weren't safe and were luckily struck down because of that
I didn't think of that, that makes sense
Related to I propose some new forums/sub forums
1. How will these new forums/sub forums benefit users?
The new forums/sub forums will allow users to access more specific and relevant discussions and information. This will make it easier for users to find answers to their questions and engage in meaningful discussions with others who share similar interests or expertise.
2. How will the new forums/sub forums be organized?
The new forums/sub forums will be organized based on specific topics or themes. This will help users navigate and find the information they are looking for more efficiently. Each forum/sub forum will have clear categories and subcategories to further refine discussions and make it easier for users to participate.
3. Will the existing forums/sub forums be affected by these changes?
No, the existing forums/sub forums will not be affected by the addition of new ones. They will continue to operate as usual and users can still access and participate in discussions within those forums/sub forums. The new forums/sub forums will be added as additional options for users to explore.
4. How will you ensure the quality of discussions in the new forums/sub forums?
The new forums/sub forums will be moderated by a team of experts to ensure that discussions are relevant, respectful, and follow the community guidelines. Users will also have the ability to report any inappropriate content or behavior, further maintaining the quality of discussions within the new forums/sub forums.
5. Can users suggest topics for the new forums/sub forums?
Yes, users are welcome to suggest topics for the new forums/sub forums. We value user feedback and suggestions, and will consider all relevant and appropriate topics for potential addition to the forums/sub forums. Users can reach out to the moderation team or submit their suggestions through a designated form.
  • Feedback and Announcements
  • New Member Introductions
