A I think I discovered a pattern for prime numbers
A user claims to have discovered a new pattern for prime numbers and developed a program that successfully identifies all primes up to 70 million, although it crashed due to RAM limitations. They believe the pattern is unique and have not found any existing documentation on it. However, responses indicate skepticism, suggesting that the pattern aligns with established mathematical concepts, particularly the prime counting function. The discussion concludes with a warning that claims of solving significant mathematical conjectures, like the Riemann Hypothesis, are unlikely to be valid. The thread is ultimately closed due to the improbability of the user's claims fitting established mathematical formats.
hotAdaptness
TL;DR Summary
I wrote a program that implements the pattern and finds the primes automatically. It worked up to 70 million then it crashed because program holds data in RAM so it can be fixed. It found all the primes up to 70 million and found no exception. I won't explain the pattern because its so complicated and its not officially mine. I couldn't find any documents about this pattern and I think its a new thing. What should I do?
Mathematics news on Phys.org
hotAdaptness said:
Summary: I think I discovered a pattern for prime numbers
The pattern you have found is
\pi(x) \approx \operatorname{Li}(x)=\displaystyle{\int_2^x \dfrac{dt}{\log t}}
Anything else can frankly be considered wrong. See
https://www.physicsforums.com/insights/the-history-and-importance-of-the-riemann-hypothesis/
and if you are interested in details
https://www.physicsforums.com/insights/the-extended-riemann-hypothesis-and-ramanujans-sum/.
Since it is highly unlikely that you have solved the Riemann conjecture, and even if, it certainly won't fit our format, this thread is closed.
Likes dextercioby
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
